It is currently Mon Jul 16, 2018 7:34 pm
Post new topic Reply to topic  [ 39 posts ]  Go to page Previous  1, 2, 3  Next
 Post subject: Re: Windows
PostPosted: Mon Oct 23, 2017 6:31 pm
Has thanked: 227 times
Been thanked: 226 times
fitzy wrote:
Desmondo15 wrote:
fitzy wrote:
I've got some external UPVC windows to paint from white to anthracite grey.
I'm going to use zinsser 123 and then two coats of zinsser allcoat exterior.
Internally I'd say the 123 is the important coat and then you can paint over that with anything really.
Sent from my SM-G850F using Tapatalk
You shouldn't need the 123 under the Allcoat mate as apparently it's the same bonding resin in both.
I was just going by what they specify on the app.
It's what they told me on the phone..... classic!
For this message the author Desmondo15 has received gratitude : fitzy
PostPosted: Mon Oct 23, 2017 7:33 pm
Has thanked: 1452 times
Been thanked: 3724 times
:dunno: regardless I'd use a bridging primer....
@ OP 1-2-3- always looks shite as it's not a covering coat. one or two coats of your chosen finish should have a smile on your face.
For this message the author wine~o has received gratitude : kevinsmbuk
PostPosted: Tue Oct 24, 2017 12:51 pm
Has thanked: 179 times
Been thanked: 26 times
Many thanks it is reassuring to hear!
What would you suggest to apply in order to reduce any brush strokes on the final coat? I was thinking maybe tiny roller or a mini sponge pad? I want it looking as close to upvc white as possible
PostPosted: Tue Oct 24, 2017 1:04 pm
Has thanked: 679 times
Been thanked: 766 times
Keep the room cold(er), use a good soft synthetic brush, get the brush wet before you start and shake the water off it, don't overbrush by trying to finish off in one coat less. Start by painting the less visible windows to get the practice in.
For this message the author OchAye has received thanks - 2: kevinsmbuk, multiman
PostPosted: Tue Oct 24, 2017 7:41 pm
I have now completed 2 coats of bullseye 123.
Can I follow up with dulux trade satinwood?
Sent from my SM-G950F using Tapatalk
PostPosted: Tue Oct 24, 2017 8:26 pm
DIYer here and completely unfamiliar with Dulux speak. Is your dulux trade satinwood water based or oil/solvent based? If it is the latter, forget about wetting the brush. The only catch with it is that it will yellow sooner rather than later unless you got plenty of light (and we don't have enough during winter months, let alone in a darker room). You will probably get a better finish with it but I don't think many people here would suggest you use an oil based paint. Also, if it is oil based, one coat per day if not per two days.
PostPosted: Tue Oct 24, 2017 8:29 pm
Elephant Man
Has thanked: 600 times
Been thanked: 1348 times
Two days? Wait till VOC 2020 hits. It'll be a week between coats. :mrgreen:
Nihil expectore in omnibus
For this message the author dynamod has received thanks - 2: fitzy, OchAye
PostPosted: Tue Oct 24, 2017 8:30 pm
It's a water based product so no issues with solvent
PostPosted: Tue Oct 24, 2017 8:38 pm
Pssst :-) Read here https://www.duluxdecoratorcentre.co.uk/product/paint/interior-trim/satin/. The one you mentioned I read is solvent based ... the other one that you did not mention (the quick dry version) is the water based one.
Jumping elephant man who responded above I think has said he likes Armestead quick dry satin, just to confuse you.
BTW. I am not clever although I would like to think so. I have made the mistake with the two dulux paints and someone here picked it up ;-)
PostPosted: Tue Oct 24, 2017 8:57 pm
You are correct! it's the quick dry so water based thank god! I suppose the only thing I wondered is it's not being painted on wood or metalImage
For this message the author kevinsmbuk has received gratitude : OchAye
PostPosted: Wed Oct 25, 2017 5:54 pm
So I also bought some Bedec Multi Surface Paint today too, as I'm not sure whether this or Satinwood would be better for finish?
I also got a decent brush, I got a Wooster silver line, so hopefully the job should go ok!
For this message the author kevinsmbuk has received gratitude : multiman
PostPosted: Wed Oct 25, 2017 6:04 pm
Has thanked: 696 times
Been thanked: 28 times
sounds like a good plan let us know how it goes
PostPosted: Wed Oct 25, 2017 10:53 pm
Why not try both paints each in a different room, two coats and come back and tell us? Just a thought :-)
PostPosted: Wed Oct 25, 2017 11:07 pm
Well there is an idea! I just keep thinking the satinwood will look smoother for some reason!!
PostPosted: Thu Oct 26, 2017 12:19 am
Whichever paint you can lay on thicker, brush the least, and does not run will probably look the best.
Users browsing this forum: Tom d'Angler and 2 guests
