It is currently Fri May 25, 2012 11:49 pm
Post new topic This topic is locked, you cannot edit posts or make further replies.  [ 31 posts ]  Go to page 1, 2, 3  Next
 Post subject: windows 7 freezing
PostPosted: Fri May 13, 2011 7:46 pm
OAP
Has thanked: 187 times
Been thanked: 2115 times
any clues guys why it freezes
CPU usage keps going of the scale 100% :scratch:
 Post subject: Re: windows 7 freezing
PostPosted: Fri May 13, 2011 7:55 pm
Has thanked: 166 times
Been thanked: 614 times
:dunno: But I've had similar a couple of occasions..cpu running into the red with not much running..
PostPosted: Fri May 13, 2011 8:00 pm
Has thanked: 134 times
Been thanked: 474 times
you have defraged disk cleaned
anti spyware and adware ??
PostPosted: Fri May 13, 2011 8:04 pm
OAP
not done anything yet BA
PostPosted: Fri May 13, 2011 8:13 pm
Has thanked: 16 times
Been thanked: 339 times
John,
Run Ccleaner first to clear out your temp files etc and other crap.
Run a scan with your UPDATED antivirus program.
Run a QUICK scan with MBAM and/or SAS
Do a Defrag
dave
But you cannot tell him much.
PostPosted: Fri May 13, 2011 8:20 pm
OAP
Will do Dave
PostPosted: Fri May 13, 2011 8:31 pm
Has thanked: 62 times
Been thanked: 218 times
Run Windows task manager (alt-ctrl-del) and look for the application that shows high numbers in the 'CPU' column. Post the name of the program that it's associated with. I'm guessing Acrobat will be the culprit.
This post may contain nuts
PostPosted: Sat May 14, 2011 12:43 am
OAP
Under Application.
Resource monitor, Skype, Uhm is running.
In processes.
iexplore.exe uses the must but only when I'm doing something.
Performon goes high ish.
AVGdump is high ish when it shows, not always there.
CPU Usage is around 5% when idle then it jumps up to 100% when I get stuck in and freezes.
Tried downloading ccleaner and it freezes.
Got the computer at home for now if you need more info.
Remember it's windows 7 and I'm not familiar with yet.
As an example I scrolled down in uhm and usage shot up to 58%
PostPosted: Sat May 14, 2011 12:51 am
OAP
What is "Sidebar" any idea.
PostPosted: Sat May 14, 2011 10:52 am
http://desktop.google.com/features.html
"Sidebar is a vertical bar on your desktop that helps you keep your gadgets organized."
http://windows.microsoft.com/en-US/wind ... s-overview
PostPosted: Sat May 14, 2011 1:51 pm
OAP
Update.
Run mBam and removed 5 low threats.
Run Ccleaner and removed about 3500mb :roll: mostly ie stuff.
Turned the thing on this morning and opened up uhm, cpu usage gradually got to 100% and the computer froze.
Had to turn the power off to shut down.
Re booted and had IE open but doing nothing, CPU usage climbed to 100% after about an hour, close IE and it was going from 5-100%
Just had a avg threat blocked "nonjun.com/oh/stat.htm" Exploit JavaScript Obvuscation (type1450)
In details its shows something to do with svhost.exe.
Any tests or information you guys want.
CPU usage just shop up to 100%, not being used or touched, only program open is task manager.
PostPosted: Sat May 14, 2011 2:26 pm
i use superantispyware its brilliant i never get anything showing on the daily avg scan but spyware will find the one that use the cpu capacity
http://www.superantispyware.com/superan ... vspro.html
PostPosted: Sat May 14, 2011 2:36 pm
OAP
Just found 2 x Trojan horse agent_r.XJ
cured I think, running scan at the moment with.
http://support.kaspersky.com/downloads/ ... killer.zip
PostPosted: Sat May 14, 2011 2:47 pm
OAP
Latest update.
Re scan found no threats, and the CPU is jumping up and down with use but not flat lining at 100% any more so may have found the problem.
I'll give it some heavy use later, and leave it running to see what it does.
PostPosted: Sat May 14, 2011 4:23 pm
John,
One way to quickly open the Task Manager is to right click on the taskbar and click Start Task Manager.
I have both Firefox and Palemoon browsers open at the moment and they are using 0 in the CPU usage and showing 128,484K for Firefox and 173,728K for Palemoon in the Memory Column.
Did you run your AV program?
What was it that found the Trojans?
dave
Users browsing this forum: No registered users and 9 guests
