-> Computers |
| Author |
Message |
Bludall Senior Member
Joined: 11 Apr 2007 Posts: 8556 Location: East Midlands
Posted: Fri Sep 05, 2008 5:13 pm Post subject: Wifi connection disable it? |
Our laptop is driving us nuts. We don't want to use the wifi connection and have removed the drivers but it still comes on . How can it be disabled, so that it doesn't light up and slow everything up looking for a connection? _________________ Never be afraid to ask, that's how we learn. |
| Back to top |
moderator1 UHM Super Moderator
Posted: Fri Sep 05, 2008 5:24 pm Post subject: |
| Try start, connect to, show all connections, tools, disconnect network drive |
| Back to top |
Posted: Fri Sep 05, 2008 5:30 pm Post subject: |
Mod1,
My oh has just had a go and apparently it wasn't connected to network in the first place. Any more suggestions? We tend to use it in the living room and plug the ethernet cable in. _________________ Never be afraid to ask, that's how we learn. |
| Back to top |
skiking Senior Member
Posted: Fri Sep 05, 2008 5:52 pm Post subject: |
If its on constantly then there should be a physical switch around the side of the lappy. A method to switch on for lappy's that don't have a switch is using the Fn keys.
Make and Model ? |
| Back to top |
ultimatehandyman Site Admin
Joined: 16 Jul 2005 Posts: 9278 Location: Darwen, Lancashire
Posted: Fri Sep 05, 2008 5:54 pm Post subject: |
My switch is on the front and I have to say that wifi can be very tempromental on my old laptop. The new one is much better, infact I even quite like the new one  _________________ DIY | DIY Video |
| Back to top |
Posted: Fri Sep 05, 2008 6:13 pm Post subject: |
IBM Thinkpad T43 _________________ Never be afraid to ask, that's how we learn. |
| Back to top |
Foggy Senior Member
Posted: Fri Sep 05, 2008 6:33 pm Post subject: |
sure that model doesnt have a switch
Double click my computer
Right click on my network places
then properties
right click on your wireless LAN
choose disable
 _________________ Button will win F1 championship 2009 |
| Back to top |
Posted: Fri Sep 05, 2008 6:40 pm Post subject: |
Foggy,
That's it!! It seems to have worked! I've turned it off now, it'll be intereting to see if the oh comments!  _________________ Never be afraid to ask, that's how we learn. |
| Back to top |
Foggy Senior Member
Posted: Fri Sep 05, 2008 7:16 pm Post subject: |
| Back to top |
Hoovie Devon DIYer
Posted: Fri Sep 05, 2008 7:50 pm Post subject: |
Easier Way ....
Fn-F5 _________________ If you have a son, DO NOT name him after a verb ....
"Which is it, man?" |
| Back to top |
Hoovie Devon DIYer
Posted: Fri Sep 05, 2008 7:51 pm Post subject: |
BTW - why are you not wanting to use the Wi-Fi connection  _________________ If you have a son, DO NOT name him after a verb ....
| Back to top |
Posted: Fri Sep 05, 2008 8:05 pm Post subject: |
The oh just plugs in the ethernet cable if he uses broadband, as it gets used in the same room as the hub.
I use it offline mostly at school. It gets used to battle nations, my oh and daughters play Age of Empires on it. _________________ Never be afraid to ask, that's how we learn. |
| Back to top |
thescruff Senior Member
Posted: Fri Sep 05, 2008 8:10 pm Post subject: |
What's the shortcut key to turn it on Hoovie _________________ Scruff |
| Back to top |
Hoovie Devon DIYer
Posted: Fri Sep 05, 2008 8:35 pm Post subject: |
The IBM Thinkpads use Fn-F5 to toggle the Wi-Fi State, so if on, Fn-F5 turns it off, and of on, Fn-F5 turns it on.
As Skiking and UHM said, some laptops have a physical switch - the HP we have does and the Sony VAIOs do (they both drive me mad as Mrs H uses the HP and knocks the switch ....."Hoovie, the network isn't working ".
Sister Hoovie has a VAIO and knocks that - calls me up ..."Brother Hoovie....."
Just checked Mrs Hoovies Dell laptop and that has a very positive physical switch on the side to turn wi-fi on and off, which is not one that can be knocked that accidentally. _________________ If you have a son, DO NOT name him after a verb ....
| Back to top |
Posted: Fri Sep 05, 2008 8:43 pm Post subject: |
Apparently, our laptop keeps picking up neighbours' wifi connections and it gets interrupted, he got fed up with it. Could he get round that one? _________________ Never be afraid to ask, that's how we learn. |
| Back to top |
