It is currently Sat Feb 23, 2019 12:59 pm
PostPosted: Sat Aug 04, 2018 11:35 am
Hello!
I'm trying to solve a suction problem with my Wickes wet and dry vacuum cleaner.
After using the machine for about a minute, I hear something, like a ball, move up inside the central column and stops the vacuum's suction.
I've just watched a clip on YouTube with on the Ultimate Handyman reviewing this cleaner ...
https://youtu.be/S_fRJStKCu0, and so was hoping I may be coming to the right place for help!
Thanking you in advance
Sam
PostPosted: Sat Aug 04, 2018 11:56 am
Has thanked: 643 times
Been thanked: 1816 times
The ball is when you use it wet mode to stop liquid going into the fan unit and blowing it. The fact that it is sucking up suggests to me that there might be a blockage somewhere and that is diverting the suction to the chamber where it is sucking the ball up. Have a good look at the pipe and opening into the dust bag.
It is usually a simple solution if you have power. Let us know how you get on. :thumbright:
Painting with BIN
PostPosted: Sun Aug 05, 2018 6:45 pm
Has thanked: 105 times
Been thanked: 358 times
If it's the same one I have, it's a very simple machine.
Are you using the foam filter? Check that's clear, check the hose is clear...mine has a tendency to block at the bend in the nozzle...and fit a new bag. Earlex/Karcher make an identical machine and the bags are easier to get.
