It is currently Wed Jul 18, 2018 5:50 am
Post new topic Reply to topic  [ 23 posts ]  Go to page 1, 2  Next
PostPosted: Sat Aug 12, 2017 3:22 pm
Has thanked: 14 times
This is what my French door looks like when it is closed and locked. Gap at the bottom of the door with draught blowing in. Has the door been fitted incorrectly?
Image: https://1drv.ms/i/s!AvxDFgUHUgNC5RaPCG4UH0_N0gUs
Pic attached . Mod 2.
Thanks in advance.
PostPosted: Sat Aug 12, 2017 3:32 pm
Has thanked: 564 times
Been thanked: 1666 times
Are the top and bottom turn locks on the other door secured?
Painting with BIN
PostPosted: Sat Aug 12, 2017 3:34 pm
Has thanked: 25 times
Been thanked: 94 times
Mine closes tighter when you push up the handle to lock they pull in a bit more, do yours?
PostPosted: Sat Aug 12, 2017 3:55 pm
Yes the top and bottom turn locks are secured on the other door.
Yeah pushing the handle up on this door does close it tighter but this doesn't fix this.
The image shows the door closed as tight as it goes. It stops where it stops and leaves the gap shown
PostPosted: Sat Aug 12, 2017 7:14 pm
Has thanked: 70 times
Been thanked: 84 times
Should be a keep at the bottom and top where the door locks in these should be adjustable
PostPosted: Sat Aug 12, 2017 10:48 pm
Are these the keeps?
File comment: Top
File comment: Bottom
PostPosted: Sun Aug 13, 2017 4:25 pm
Bump
PostPosted: Sun Aug 13, 2017 7:53 pm
Has thanked: 990 times
Been thanked: 1848 times
They are,these are adjustable but so are the doors,you can adjust the hinges to bring the door closer to the seals as well as adjusting the keeper.
PostPosted: Mon Aug 14, 2017 1:12 pm
I've tried adjusting the hinges before with no luck. I think the keepers may need adjusting. However, if you look closely at the keeper at the bottom, it is not adjustable unlike the top one.
Should I replace the bottom keeper with an adjustable one?
Or perhaps swap the keepers around by moving the adjustable keeper to the bottom and the non-adjustable keeper to the top?
PostPosted: Mon Aug 14, 2017 6:18 pm
The shoot bolt that locks into the keep may need adjusting when doors are locked can you push the inside and see if there is movement, it maybe that the bolt is not going down enough, there could be several reason all hard to describe/tell without seeing
For this message the author Thewindowguy has received gratitude : flembot
PostPosted: Mon Aug 14, 2017 6:34 pm
Go outside and push on the door whilst it is locked to see if there is movement?
PostPosted: Mon Aug 14, 2017 6:48 pm
When I go outside, close the door fully and lift the handle upwards to engage the locking system. Then when I push against the door there is movement.
PostPosted: Mon Aug 14, 2017 6:51 pm
Has thanked: 1452 times
Been thanked: 3725 times
:dunno: I'm no expert but in your first pic there seems to be a metal thingamybob stopping the door closing fully.
can you take a pic of that area with the door open from the inside ?
PostPosted: Mon Aug 14, 2017 7:29 pm
Good spot wine-o. These screw on the top and bottom of the stop door and are easy to put on the wrong way round. This looks to be the case here. You have to take the door off to access this and move.
PostPosted: Mon Aug 14, 2017 7:49 pm
So my mother was wrong... "it" doesn't make you blind ...
For this message the author wine~o has received gratitude : steviejoiner74
