It is currently Wed Feb 20, 2019 8:30 pm
Post new topic This topic is locked, you cannot edit posts or make further replies.  [ 11 posts ]
PostPosted: Thu Dec 20, 2012 9:41 am
Has thanked: 29 times
Been thanked: 115 times
Well I'm back at my folks house for Christmas, having already fixed numerous other things around the house (as seems to be my job every time I return home) I've turned my attention to the broadband.
Current it's getting 300kbps downstream with 20-32db noise margin, 500kbps upstream with 11-22db noise margin.
Same with both the sky sagem router and cisco router, disconnected the extension line, swapped all the cables and microfilters, tried adjusting the target SNR.
It is clearly a problem with the line, so on the blower for the 9 millionth time to sky and they reckon we'll be liable to pay for line repairs.
Does anyone know this kind of thing a bit better, because that doesn't seem right to me, if we're renting the line and it's of a substandard quality because of natural degradation then surely it falls to sky, or BT to sort it out free of charge?
Anyone know whats the best way to go about getting BT/ Sky to get their arse into gear?
Cheers in advance guys :thumbright:
PostPosted: Thu Dec 20, 2012 9:59 am
Has thanked: 214 times
Been thanked: 192 times
report a fault with BT I reckon, Its still their infrastructure.
If its a problem with the line I think its bt free of charge if its something the consumer has broken or messed about with they will charge for it.
- Dave
http://www.invertedcircle.co.uk
PostPosted: Thu Dec 20, 2012 10:10 am
Has thanked: 40 times
Been thanked: 1429 times
I was always understood it to be as:
You pay your broadband / line rental fee to a 3rd party (SKY in this case) Any problems you have should be pointed towards your ISP. Your ISP will / should contact the line provider (Open reach in this case)
Your contract is with SKY therefore Open reach will not work for you, unless you pay them.
That is the "joys" of having an ISP that is not your line provider. This was told to me by an Open reach chap who came to fix a fault with my line, he said I can call them direct because my phone provider is BT, but any one else (such as SKY) can't.
Good luck.
PostPosted: Thu Dec 20, 2012 10:25 am
Has thanked: 349 times
Been thanked: 1825 times
YOUR responsibility stops at the NTE socket (where the line comes into your property). Any problem on the 'outside' of this socket belongs to BT whoever may be providing the service. The LINE is BTs property and is only rented to you or your provider.
I had endless problems with my download speed and had to constantly get BT to do a 'reset' at the exchange. It turned out to be the MODEM (BT-supplied) as I eventually swapped it out and the fault disappeared.
PostPosted: Thu Dec 20, 2012 11:41 am
Has thanked: 107 times
Been thanked: 469 times
This is the reason that I stuck with BT as my broadband supplier as they can't blame anyone else for any issues, which thankfully I've not had. The only exception to that is if you're in a Virgin Cable area.
Cheers,
Darren
PostPosted: Thu Dec 20, 2012 12:10 pm
So by that, should Sky pay for the repairs or will my parents be liable?
I'm 100% it's a line fault outside of the property and not due to negligence or tampering.
They've always had crap connection, always cut out loads and what have you but it was never this slow.
I reckon it has something to do with the neighbours house getting hit by lightning a few years ago, everything on a phone line within a few houses got fried, can't have been good for it.
PostPosted: Thu Dec 20, 2012 1:09 pm
BT should be liable
- Dave
PostPosted: Thu Dec 20, 2012 8:21 pm
I still say you need to contact your ISP (you can of course try calling BT, but...............)
Although your neighbours property was struck by lightening a few years ago, sorry I think that is a red herring. Lightening can and does strike, but companies like BT have lightening arrestors to protect equipment, if these fail, equipment literally gets blown up, there for it no longer works. When this happens the equipment has to be changed, end of story. So as the strike was some years ago, its safe to say anything that got hit will have been changed.
The one thing that doe not help is rain. If that gets into a major junction box that can upset your BB speed, but of course its not raining when they check.
PostPosted: Fri Dec 21, 2012 8:57 am
Has thanked: 840 times
Been thanked: 940 times
Yep, call Sky first.
As said they will log the fault with BT. Openreach will investigate the fault, but will charge if fault is found in the property.
BT doesn't get any priority over Openreach. They have to log the fault and get allocated an engineer in the same queue as everyone else.
Dave
www.drlgas.co.uk
PostPosted: Sun Dec 23, 2012 6:07 pm
Has thanked: 13 times
Been thanked: 2 times
I have had the same issue and all I can say is good luck.
I contacted SKY as I had no phone line (neighbours tree was the cause) and they sent out a BT engineer who came in and buggered off to the exchange never to be seen again, still not working. Long story short...6 weeks this went on for, same pattern.
What SKY do is pay for the least BT engineer service of 2 hours, if it is not fixed within 2 hours, they are off and another appointment is to be made.
I kicked up a stink with SKY, gave them 48 hours to respond and resolve if they didnt resolve this time, I was consulting legal advice. As soon as I suggested that, had a guy for 6 hours till it was sorted, got SKY movies & Sports for a year free and doscounted B/Band. Be very assertive with them.
PostPosted: Sun Jan 13, 2013 7:21 pm
Communications Expert
This is why I always recommend that people choose BT or Virgin for the BB. 3rd party companies like Talk Talk, Plusnet, Sky etc etc give you something in one hand then take it out of the other IE Crap engineering support. At least with BT or Virgin you stand a chance of getting a man and a van out.
You may hit a brick wall when calling BT - you are no longer their customer, so they will not prioritise you.
Good Luck and as soon as possible, go back to BT or Virgin....
