It is currently Sat Aug 18, 2018 9:43 pm
PostPosted: Sat Apr 23, 2016 11:56 pm
Hello,
I have an old metal up and over garage door. At the point where the up and over support arm hinge attaches to the garage door via a bracket and small stress crack has appeared on the door itself. This is a common fatigue failure with this garage door type (Henderson, Merlin)
This is at the moment a small crack, however the door under goes a lot of stress (shear?) at this point. My idea to re-enforce it, before it becomes any worse, is to fill the crack as much as possible with some epoxy filler (JDWELD?) and then place a strip of metal of over it (hinge plate) perhaps allowing the epoxy to fill the hinge holes and securely hold the plate.
Then I would rivet the hinge plate so that it was very securely held in place over the weak area.
Does this sound like a good repair?
If so, what type of rivet is best to use? I also head that using a washer behind the rivet gives extra support? Is this correct?
Many Thanks
PostPosted: Sun Apr 24, 2016 12:10 am
Has thanked: 44 times
Been thanked: 1303 times
As I understand it, rivets are only used when you can't access both sides. (or for cheapness)
So I would ask, have your not considered nuts and bolts, something like (my old favourite) 6mm gutter bolts?
PostPosted: Sun Apr 24, 2016 12:49 am
That is an interesting one. I was considering nuts and bolts but I was under the impression (maybe incorrectly) that lots of small rivets were a more secure option and neater. I thought that drilling a larger hole in what is thin galvanised steel would make it even more weak.
Something to consider though.
If only I had a welder.....I think that is probably the best long term solution.
PostPosted: Sun Apr 24, 2016 9:31 am
Has thanked: 70 times
Been thanked: 84 times
Pop rivets would be the ones, 4.8mm by something like 12mm long would do depending on the thickness of materials, a washer is not needed if the hole is the right size and material is thick enough. Be warned cheap pop rivet guns are not worth it
PostPosted: Sun Apr 24, 2016 12:56 pm
Has thanked: 1103 times
Been thanked: 1025 times
Is it just the sheet metal panel that's cracked, or is the frame (I assume there is one) cracked as well?
Anyway I mended our old garage door with pieces of steel sheet bolted (with gutter bolts as suggested) on behind.
Pop rivets come with various heads and diameters and the grip length (ie the thickness of material they will join) is given on the pack if you look. Drilling a small hole at the end of a crack can stop it "running" any further.
