-> Painting & Decorating Forum |
| Author |
Message |
kath81 Junior Member
Posted: Mon Aug 25, 2008 7:29 pm Post subject: Which paint for walls? |
Just been looking back through some of the posts and most people seem to be in agreement that you shouldn't put silk on walls. Am i right in thinking this is right and if so why. The Dulux paint i have just bought says for walls and ceiling. Is this why i am having terrible patchy paint on wallpaper/ (see earlier post).
thanks |
| Back to top |
Telmay Senior Member
Joined: 09 Mar 2007 Posts: 2394 Location: Worthing, West Sussex
Posted: Mon Aug 25, 2008 7:50 pm Post subject: |
Out of all the finishes silk is the hardest to get a decent even coat, it can be used on ceilings and walls, but is not the most user friendly paint in the world _________________ "Where would we be without rules?
France! And where would we be with too many rules? Germany!" |
| Back to top |
Posted: Mon Aug 25, 2008 7:59 pm Post subject: |
| Is that why the paint looks so uneven? Which would you recommend to use? In the colour my daughter has choosen it is only silk or matt. Would matt give a better finish. I am so desperate now i think the wall looks awful. Just one more question (well 2 actually)can i paint a different finish onto silk and would that cover the uneveness? Thanks for replying. |
| Back to top |
Posted: Mon Aug 25, 2008 9:34 pm Post subject: |
Matt is a lot more forgiving and will give a better finish than the silk, the only problem now is that Matt is not recommended to go directly onto silk - what I would recommend is that you go to B&Q and get the same colour mixed in store as a soft sheen, this can be painted directly onto the silk and will give you a better finish than the silk. Just be prepared to give it two coats. _________________ "Where would we be without rules?
| Back to top |
Ragged Trousered Phil Junior Member
Posted: Tue Aug 26, 2008 5:33 pm Post subject: |
| soft sheen or mid sheen would be the paint for you my friend. Unless you have perfect walls which is virtually impossible then you should give silk a body swerve |
| Back to top |
