It is currently Fri May 25, 2012 11:28 pm
Post new topic This topic is locked, you cannot edit posts or make further replies.  [ 12 posts ]
PostPosted: Sat May 09, 2009 4:14 pm
I'm shortly to start wiring a new bungalow. I've done plenty of electrical work before, but not an entire building. For the power ringmains, should I run the cable in the loft, dropping down and back up to each socket, or go from socket to socket horizontally around the walls? This would mean drilling through the 4"x2"wooden framing uprights and would use much less cable but would make a future rewire more difficult. Is there a preferred method? Thanks for any replies.
 Post subject:
PostPosted: Sat May 09, 2009 6:01 pm
Has thanked: 10 times
Been thanked: 75 times
Will the cables be run in the loftor wall insulation?
 Post subject:
PostPosted: Sat May 09, 2009 6:35 pm
I was going to run them on the woodwork in the loft, or if horizontally around the walls, on top of the 100mm slab insulation behind the plasterboard. The house is a little unusual in construction as it's a traditional stone farm building with an internal timber frame which supports the roof, hence it's substantial.
 Post subject:
PostPosted: Sun May 10, 2009 9:46 am
Has thanked: 2 times
Been thanked: 99 times
Loft and drop cables down to each point is my preferred method i must admit, makes more logical sense, bit more cable but a better job in my oppinion.
Nick
 Post subject:
PostPosted: Sun May 10, 2009 10:09 am
OK, many thanks.
 Post subject:
PostPosted: Sun May 10, 2009 11:02 am
Please be aware of table 4d5 reference method 101# when using 2.5 or even 4mm for ring final circuits. Good old 17th :roll:
20A rings anyone?
 Post subject:
PostPosted: Sun May 10, 2009 11:56 am
I take it you mean to keep cables clear of insulation? I was going to run three separate ring mains, kitchen, living room and bedrooms. I already installed the consumer unit, which the Elec. Co. were happy with when they ran the supply to it, and juice is on. Are there minimum distances apart for cable clips? Would it be gilding the lily to run boards down the length of the loft, under the trusses, to carry the cables? I'm a bit of a perfectionist and like things to be tidy and labelled for future reference, unlike my present house, wired by the previous owner, a sparky..!! No implications should be drawn from that!
 Post subject:
PostPosted: Sun May 10, 2009 12:43 pm
How are you getting the part P stuff sorted?
 Post subject:
PostPosted: Sun May 10, 2009 12:47 pm
My neighbour is a sparky and he is going to check my stuff and do the cert.
 Post subject:
PostPosted: Sun May 10, 2009 12:54 pm
Has thanked: 21 times
Been thanked: 27 times
though according to your profile location your north of the border so Part P doesnt apply (?)
still goes through building control though possibly (?)
 Post subject:
PostPosted: Sun May 10, 2009 1:01 pm
Oh yes didnt pick up on that but the scottish have a requirment too. If your niegbour is a spark why not ask his opinion as he can see the building and its requirments afterall he's the one putting his name to it!!!!
James
 Post subject:
PostPosted: Mon May 11, 2009 11:49 pm
Been thanked: 1 times
A design and install in a new build - blank sheet of paper - why are you installing ring finals?
They connected the supply with no proof that the installation was safe?
Naughty.
Yes, and it's a bit worrying that you're tackling a task like this without having the publications you need, e.g. in this case GN1.
They've got to go somewhere. Why not use proper cable tray?
And time for another "why would you" Q: You're doing a new build and you've chosen to use one of those disgusting trussed roofs?? :wtf:
You'll like this idea then - where you have cables running at right angles through floor joists, instead of having them sagging between each one, fix short pieces of galvanised trunking between the joists, supported on mini-joist hangers...
I'm sorry - I can't come in to work today, the voices are telling me to stay at home and clean the guns.
Users browsing this forum: No registered users and 15 guests
