Page 1 of 1
[ 8 posts ] |
| Author |
Message |
ropper
Posted: Fri Oct 21, 2011 2:43 pm |
| Newly registered Member |
Joined: Sat Nov 18, 2006 12:20 pm Posts: 86 Has thanked: 2 times Been thanked: 0 times
i want to flush my radiators but before i take them off to use pressure washer i want to put some sludge remover thorugh the system as some radiators take an age to heat and some are barely warm across the bottom.ive tried bleeding them but all i geti is water coming out and no air.i want something that can be put in system through one of the radiators
| Top |
Posted: Fri Oct 21, 2011 3:16 pm |
| Senior Member |
Joined: Fri Jan 20, 2006 5:51 pm Posts: 3210 Location: Essex Has thanked: 17 times Been thanked: 266 times
A choice of Fernox DS40 or Sentinal X400. You have to be careful that you do not get leaks after use.
| Top |
register or
log in
aeromech3
Posted: Fri Oct 21, 2011 4:09 pm |
| Senior Member |
Joined: Fri Feb 26, 2010 11:16 am Posts: 492 Location: Camberley Surrey Has thanked: 25 times Been thanked: 71 times
I wonder, if you are going to remove the rads, chemical cleaning will cause the sludge to emulsify and pass around the whole system, it does not magically disappear only becomes more fluid to drain out. If you are prepared to remove the rads to power flush them I would consider doing that 1st (be sure to have containers to catch the muck and plenty of old towels as it contains irons and stains the devil on carpets, a couple of blanking plugs would be best whilst getting them outside without a trail of drips, been there done that). Then, after getting the system running again, chemical clean leaving it in for a couple of weeks use, before draining and flushing and ultimately inhibiting.
| Top |
register or
log in
ropper
Posted: Fri Oct 21, 2011 4:29 pm |
just ordered the x400 1ltr part of double pack with x100 inhibitor with screwfix at a good price how much of the 1ltr do i use of both
| Top |
register or
log in
aeromech3
Posted: Fri Oct 21, 2011 7:02 pm |
| Senior Member |
Full instructions come with pack, usually enough for 3 to4 bed house size system. Not sure how long they recommend to leave in but my local Plumbers told me 2 weeks to a month and this worked good to rid boiler knocking as well, but a good few flush operation before I was happy to put inhibitor in.
| Top |
register or
log in
northwales4u
Posted: Sun Oct 23, 2011 7:17 am |
| Senior Member |
Joined: Sun Jul 25, 2010 5:32 pm Posts: 2181 Location: Wrexham, Wales Has thanked: 45 times Been thanked: 124 times
I put in some Sentinal in my system yesterday and it says to put it in for 1 hour or until the system is working properly. Still waiting....
_________________ Mike If you feel you have benefited from the Free advice given on the Forum, Please consider making a donation to UHM's Nominated charity, read all about it and donate here :
| Top |
register or
log in
gas4you
Posted: Sun Oct 23, 2011 11:23 am |
| Senior Member |
Joined: Mon Apr 13, 2009 8:03 pm Posts: 3577 Has thanked: 51 times Been thanked: 230 times
Leave the X400 in for a couple of weeks before flushing it out.
It is not designed as a quick flushing agent. For a quick job you should have got X800 which takes about an hour.
Use all of the litre bottle you have of both of them.
_________________ Dave
www.drlgas.co.uk
| Top |
register or
log in
ropper
Posted: Sat Oct 29, 2011 1:57 am |
| Top |
register or
log in
Page 1 of 1
[ 8 posts ] |
