It is currently Wed Jan 23, 2019 8:13 pm
 Post subject: What size sleeve anchor?
PostPosted: Fri May 18, 2018 5:17 pm
Going to mount our 50" LED TV on the wall on the chimney breast (chimney capped, fireplace not in use!!) which is brick which has been skimmed over, plan is to use concrete sleeve anchors.
I was planning on using either the 8 X 65mm M8 or the 10 X 75mm M8 Easifix ones from Screwfix, any suggestions on which to choose? Or would a different size suit better?
PostPosted: Fri May 18, 2018 5:20 pm
Has thanked: 225 times
Been thanked: 172 times
What is the weight if the tv? Size is irrelevant, weight isn't.
PostPosted: Fri May 18, 2018 10:41 pm
16kg
PostPosted: Sat May 19, 2018 5:15 am
Always better to over spec on things like this. Go for 10mm fixings at least 4 but no harm in using more if bracket allows.
Drill holes slightly downwards, this prevents fixings pulling out.
I'd go for the 10mm ones if I was fitting for a customer.
