-> General DIY forum |
| Author |
Message |
tpwuk Member
Posted: Tue Aug 19, 2008 11:27 pm Post subject: what's the best hinge to use? |
Hi guys,
I've fitted a recessed cabinet in my bathroom and I'm trying to figure out what would be the most suitable hinge to use for the door. My intention is to have a mirrored door sitting flush up against the wall when closed. To kind of give the illusion it's just a mirror hanging on the wall.
I tried some concealed cabinet hinges from B&Q - similiar to the ones used in kitchen cupboards but when closed, the door is raised off the wall by about 1 cm on the side where the hinges are fitted.
Basically I want to achieve something very close to this:
http://www.concealedcabinet.com/
But I can't seem to find those hinges anywhere.
Thanks in advance,
Glenn |
| Back to top |
big-all Pro Carpenter
Joined: 16 Dec 2006 Posts: 2629 Location: redhill surrey an auld reekie laddie
Posted: Tue Aug 19, 2008 11:59 pm Post subject: |
they are normal kitchen hinges they are set in the usual few mm from the edge  _________________ we are all ------------------still learning |
| Back to top |
dewaltdisney Senior Member
| Back to top |
Hoovie Devon DIYer
Posted: Wed Aug 20, 2008 9:29 am Post subject: |
I have done exactly the same thing in my bathroom and you have to make sure the edge of the door is at the edge of the cabinet - then there should be no problem.
As Big-All says, they are standard kitchen hinges so look at one of your kitchen cupboards and copy it _________________ If you have a son, DO NOT name him after a verb ....
"Which is it, man?" |
| Back to top |
tpwuk Member
Posted: Wed Aug 20, 2008 11:49 am Post subject: |
Thanks guys.
When the door is open, the edge of the door is only about 2mm from the frame of the cabinet. When closed it's about 12mm!?  |
| Back to top |
Posted: Wed Aug 20, 2008 1:07 pm Post subject: |
you must have your hinges 10mm to far away from the edge off the door
forcing you to mount your hinges 10mm to far forward on the cabinet when open!!!! _________________ we are all ------------------still learning |
| Back to top |
tpwuk Member
Posted: Wed Aug 20, 2008 3:30 pm Post subject: |
| Hoovie wrote: |
As Big-All says, they are standard kitchen hinges so look at one of your kitchen cupboards and copy it |
I don't suppose you have a pic handy please? Cheers, Glenn |
| Back to top |
Posted: Wed Aug 20, 2008 5:17 pm Post subject: |
do you have any kitchen units in your house!!!
if so look at the cabinet that will give you the measurments that your hinges need to be set at
does the front of your cabinet overhang the side by around 10mm!!! _________________ we are all ------------------still learning |
| Back to top |
tpwuk Member
Posted: Wed Aug 20, 2008 5:39 pm Post subject: |
| No, no over hang. Yes I have kitchen cupboards. I get your point...I will go and compare these. Thanks for the help guys. |
| Back to top |
tpwuk Member
Posted: Thu Aug 21, 2008 9:16 am Post subject: |
| Got it fitted now. As you said, I replicated my kitchen cupboards. Thanks again. |
| Back to top |
