It is currently Wed Feb 20, 2019 3:36 am
Post new topic Reply to topic  [ 32 posts ]  Go to page 1, 2, 3  Next
PostPosted: Sat Feb 03, 2018 2:36 pm
Hi all, the cupboard alone is 25kg, and the wall is breeze block with a 50mm gap (yes 50!) between that and the plasterboard. Looking for suggestions as to what fixings to use here please...
PostPosted: Sat Feb 03, 2018 3:44 pm
Has thanked: 999 times
Been thanked: 1878 times
If there’s a 50mm gap that suggests the wall is framed with 50mm timber battens,highly unlikely it’s dot dabbed with that sort of gap.
What you need to do is cut out sections of the plasterboard and put solid dwangs/noggins in to take the fixings for the unit.
Don’t even think about using toggles or plasterboard fixings.
PostPosted: Sat Feb 03, 2018 4:23 pm
What would you recommend I use to fix the noggins? Something like frame fixings?
PostPosted: Sat Feb 03, 2018 5:05 pm
Has thanked: 410 times
Been thanked: 1500 times
If the wall is framed with 50mm timbers they will be at regular intervals across the wall, fix the noggins horizontally in between two adjacent uprights with ordinary wood screws.
PostPosted: Sat Feb 03, 2018 6:59 pm
Has thanked: 8 times
Been thanked: 14 times
A 50mm gap at still be a dot n dap wall.
If it's a brick wall behind then you can use 'corefix dot and dab fixings' from HPP. Another option is to use the grip it fixings available at screwfix.
https://www.screwfix.com/p/gripit-blue- ... pack/7518j
Good luck
PostPosted: Sat Feb 03, 2018 7:17 pm
Good luck
I’m not wanting to poo-poo you’re suggestions but corefix dot and dab fixings aren’t really suitable for kitchen unit brackets as the screws need to be 20-30mm next to each other on the bracket.
And grip it fixings are in no way suitable to hang kitchen units from.
Dwangs/noggins are the way to go here.
For this message the author steviejoiner74 has received thanks - 2: Job and Knock, Ktuludays
PostPosted: Sun Feb 04, 2018 8:37 am
Has thanked: 140 times
Been thanked: 167 times
This article from the site owner may help you
http://www.ultimatehandyman.co.uk/how-t ... ng-dot-dab
http://buyrigifixonline.co.uk/
Mike
For this message the author London mike 61 has received thanks - 2: Cantseeitfrommyhouse, wine~o
PostPosted: Sun Feb 04, 2018 10:23 am
Has thanked: 36 times
Been thanked: 109 times
As long as it's minimum 12.5mm thick wallboard in good condition you'll be fine with these...
https://www.toolstation.com/shop/p73656
p*ssing about with noggins is seriously overkill for something as light as a kitchen cupboard.
PostPosted: Sun Feb 04, 2018 11:38 am
Fill it with dog food, bottles of booze or crockery (or many other common items) and it's no longer light.
For this message the author ayjay has received thanks - 2: Dave54, steviejoiner74
PostPosted: Sun Feb 04, 2018 11:44 am
This is one of the growing problems with this forum now,people giving out bad advice. I’m sorry but anyone endorsing putting kitchen cabinets up with plasterboard fixings doesn’t know what they’re talking about. Fill it with plates,tins etc and it’s really heavy. Take a look at the brackets they hang off....you’re relying on a board fixing 30mm of plasterboard then another board fixing. The plasterboard will fail,that’s a given.
That’s my final say on the matter.
For this message the author steviejoiner74 has received thanks - 2: Dave54, Job and Knock
PostPosted: Sun Feb 04, 2018 12:17 pm
Mr. Grumpy
Has thanked: 31 times
Been thanked: 116 times
Personally I wouldn't hang kitchen cabinets with plasterboard fixings. Even if they don't break, they can start to loosen and pull through as I have seen in my brothers house. Problem is when you fill it to the brim with plates and start putting things on top of cabinets the weight starts to build.
I do wonder if you could use several larger frame fixings (M10 or so) and a furniture spacer (between plasterboard and wall) to hold the brackets but others can advise if suitable or not. Just a thought
PostPosted: Sun Feb 04, 2018 12:43 pm
Has thanked: 643 times
Been thanked: 1815 times
The important issue here is that the cabinet might be light but it gets stuffed with heavy things so the fixing is important. I know it will be a pain to cut the plasterboard back and insert a support batten but it is the way to go. the gap is likely to be 50mm plus 12.5mm to get it level with the existing wall surface so you may have to make this width up by laminations. A good timber yard will cut it up for you.
Good luck with doing it :thumbright:
Painting with BIN
PostPosted: Sun Feb 04, 2018 1:17 pm
Has thanked: 51 times
Been thanked: 82 times
London mike 61 wrote:
:withstupid: Perfect for the job - I have put up 8 kitchen wall cabinets in a similar circumstance with them, and they are good and solid with crockery and other heavy stuff in them. Forget any plasterboard fixings.
Colin
PostPosted: Sun Feb 04, 2018 4:20 pm
Yeah; you being one of them. :roll:
PostPosted: Sun Feb 04, 2018 5:36 pm
Anybody advocating using toggle fixings to hang kitchen units from is a complete amateur and would be sacked on the spot if caught doing this on site. I’ve taken the bait and responded to you,you’ll feel much better now.
Please enlighten the forum and tell us what you do for a living?
