It is currently Fri Feb 22, 2019 12:49 am
 Post subject: What Coupler
PostPosted: Sat Mar 03, 2018 12:49 pm
Has thanked: 643 times
Been thanked: 1816 times
As you may have read in my previous post, I cut my condensate pipe to get out of trouble. Now we are thawing I am looking to repair the pipe but I am not sure what fitting. The pipe is 3/4" plastic but I cannot see any straight couplers that size. The boiler buoy I mentioned is naturally out of stock at the minute so I will revisit that in the warmer weather. Ideally a pushfit coupler would be good as Mrs D will have to do the job due to my present incapacity. Can some kind soul point me in the right direction.
Thank you
Painting with BIN
 Post subject: Re: What Coupler
PostPosted: Sat Mar 03, 2018 1:40 pm
Has thanked: 840 times
Been thanked: 940 times
Plumb Center part no F41618
This is a compression fitting.
Other than that a standard overflow solvent weld coupling
Dave
www.drlgas.co.uk
For this message the author gas4you has received gratitude : dewaltdisney
PostPosted: Sat Mar 03, 2018 3:43 pm
Thanks Dave :thumbright: It got me thinking if I use a metal compression fitting as a joint then perhaps I could use this tee https://www.toolstation.com/shop/p71693 ... r=3%2F4%22 with a bit of copper and an elbow to provide an emergency drain off in the future. I was not sure if the acidity in the condensate would cause issues with metal??
Cheers
Painting with BIN
PostPosted: Sat Mar 03, 2018 4:07 pm
Has thanked: 1207 times
Been thanked: 1096 times
I don't really know for sure, but I do know that even dilute sulphuric eventually eats most "normal" metals apart from stainless. Seen it happen in industry.
There's a list here.
http://www.roymech.co.uk/Useful_Tables/ ... als_1.html
Looks like even bronze will be corroded.
I'd use plastic if possible.
For this message the author Dave54 has received gratitude : dewaltdisney
PostPosted: Sat Mar 03, 2018 4:16 pm
It will over time.
Don't use anything metallic.
Dave
www.drlgas.co.uk
For this message the author gas4you has received thanks - 2: Dave54, dewaltdisney
PostPosted: Sat Mar 03, 2018 4:24 pm
Looks like the solvent weld then :thumbright:
Painting with BIN
PostPosted: Tue Mar 06, 2018 10:23 am
The Vaillant engineer called today and he was a top bloke and repaired the condensate pipe for me (using the fitting Dave suggested which I had got). He kindly replaced the igniter head, as it was a bit corroded, and checked it all over for me. All over until the next sub zero cold spell.
Thanks to all who helped with advice
Painting with BIN
For this message the author dewaltdisney has received gratitude : gas4you
