It is currently Fri Jan 19, 2018 1:50 pm
Visit Thermo worx
PostPosted: Sun Feb 06, 2011 10:17 am
Has thanked: 11 times
It seems that I need a 3 core cable to my hot water cylinder stat. The only 3 core I can find in the shops has live neutral and earth wires. I know with light switches the neutral can be used for live and should have a red sleeve on it but I am reluctant to use the earth wire with a sleeve. Is there a 3 core cable made that does not contain an earth or is it acceptable put a red sleeve on the earth wire of a cylinder stat?
thanks
Glassescase
PostPosted: Sun Feb 06, 2011 1:20 pm
Has thanked: 1265 times
Been thanked: 1193 times
I'm not sure if the cylinder stat requires an earth or not, but you can get three core and earth-
dead link removed
It is also heat resistant, which is a good idea when wiring near a cylinder etc.
Check out our nominated charity
PostPosted: Sun Feb 06, 2011 2:16 pm
Has thanked: 422 times
Been thanked: 3902 times
You need a 4core Com-1-2-E
Com-1 make on fall.
Com-2 make on rise.
PostPosted: Sun Feb 06, 2011 9:31 pm
Hi thescruff,
4 core? The instructions only show 3 terminals, 1, 2 and C. Is E earth? If using 4 core would I just leave the earth disconected?
Glassescase
PostPosted: Sun Feb 06, 2011 11:37 pm
Been thanked: 9 times
0.75mm 3 core flex
PostPosted: Sun Feb 06, 2011 11:41 pm
glassescase wrote:
Hi thescruff,
Glassescase
You need 4 core because you shouldn't use the earth, some stats have an earth terminal you can use.
Brown-Com
Yellow-2.
Blue (sleeved)-1
PostPosted: Mon Feb 07, 2011 12:02 am
4 core it is. Was surprised chap in the shop said use 3 core and sleeve the earth. .75 flex?.
This whole job has turned out to be more of a headache then I'd expected it to be.
Nothing has been "easy" and my set up does seem to match the norm and so the instrctions I have with all the products have come up short.
Everyones help and advise is appreciated. A trip to the shops for cable is on the cards for sometime this week.
Glassescase
PostPosted: Mon Feb 07, 2011 12:52 am
shouldn't he check to see if his valves are spring loaded to off before wasting money on 4 core ?
PostPosted: Mon Feb 07, 2011 1:28 am
Glassescase
If you are having problems with wiring, post what you are trying to do, and with what, and we can help.
PostPosted: Mon Feb 07, 2011 7:03 pm
Has thanked: 3 times
Been thanked: 149 times
Its considered good practice to run an earth to all electrical parts of a central heating system. Even if the stat is double insulated , the cable needs to be protected by incorporating an earth conductor.
Nick
PostPosted: Mon Feb 07, 2011 7:13 pm
Nick
my point was that if the stat is just making and breaking why would it need 3 conducting cores ?
whilst it may be a change over switch it's possibly not going to be used as one, hence 3 core will do the job
PostPosted: Mon Feb 07, 2011 7:43 pm
As Scruff jas said the cable needed is a 3 conductor PLUS earth as the connections are COM and 1 make on fall of temperature
COM and 2 Make on rise of temperature
As the OP has stated he needs three cores we are to take it he is wiring a Y plan type of heating system where this is normal wiring practice .
Not saying your wrong, but if he does need three live conductors then your way would see him using the earth as a live conductor and this is prohibited in the wiring regulations.
Nick
PostPosted: Mon Feb 07, 2011 7:57 pm
groan ....
PostPosted: Mon Feb 07, 2011 8:31 pm
:wtf: is that meant to mean ????
If you cannot contribute constructive help then whats the point in posting at all ???
