It is currently Fri May 25, 2012 10:51 pm
Post new topic This topic is locked, you cannot edit posts or make further replies.  [ 16 posts ]  Go to page 1, 2  Next
 Post subject: WC Cistern drips
PostPosted: Thu Nov 10, 2011 9:08 pm
Has thanked: 30 times
Hi all
WC cistern still drips into pan after it has been flushed then every so often cistern refills the water that has dripped out of cistern, it is a duel flush cistern,do I need a new syphon? :dunno: Would welcome any advice.
Thanks in advance
 Post subject: Re: WC Cistern drips
PostPosted: Fri Nov 11, 2011 12:03 am
OAP
Has thanked: 187 times
Been thanked: 2115 times
Probably just a bit of grit under the seating, and good clean may do the job.
For this message the author thescruff has received gratitude : oneotu
PostPosted: Fri Nov 11, 2011 12:14 am
Thanks thescruff
but but does that mean I will have to dismantle the cistern to get to the "seating"?
PostPosted: Fri Nov 11, 2011 12:18 am
OAP
Depends on the type but you should be able to take the part out from inside the cistern
PostPosted: Fri Nov 11, 2011 12:34 am
Thanks once again scruff
I think its called a veriflush drop valve, I'll have a go, but not tonight, and get back to you and let you know how I went on.
PostPosted: Fri Nov 11, 2011 9:38 pm
Hi thescruff
Had a go today with the cistern but the drop valve does not want come apart!
as its a close coupled WC looks like I'll have to take the cistern off to get the valve out.
Thanks for for your reply
PostPosted: Fri Nov 11, 2011 9:45 pm
OAP
Can you post a pic of the inside.
PostPosted: Fri Nov 11, 2011 10:10 pm
I'll have a go tomorrow and see if I can upload it
Thanks scruff
PostPosted: Fri Nov 11, 2011 10:24 pm
OAP
There's a how too at the top of the index.
PostPosted: Sat Nov 12, 2011 3:16 pm
Hi thescruff
Here goes with the photo on inside cistern,
the red part does not want to come out of the white part.
PostPosted: Mon Nov 14, 2011 9:28 pm
Has thanked: 29 times
Been thanked: 11 times
just pretend the red part is not there.
hold the white part around the mid position, twist it anti-clockwise (carefully) about a quarter turn, then lift it out. now wipe/clean off any ''debris'' in the lower section still in the toilet. now replace the part you took out in reverse (clockwise) order.
good luck.
Men will always be kids. Even after they have grown up, they keep trying to go back where they originally came from!
For this message the author kintangoman has received gratitude : oneotu
PostPosted: Tue Dec 13, 2011 3:08 pm
Thanks kintangoman
Finally brave enough to following your instructions and the red part came out ok
cleaned the rubber washer/diafram replaced but it still drips do you think if I replace the red part and the washer/diafram it would solve the problem??
PostPosted: Tue Dec 13, 2011 5:41 pm
Hello Oneotu, I'm still at work so will get back to you later. The Scruff or one of the other tradesmen (or tradeswomen) may give you more info.
Are you sure it is not the Fill Valve that is faulty, thus causing the overflowing?
Is there evidence of water leaking inside toilet pan cotinously or does the leaking only present itself once the toilet has filled up after flushing?
PostPosted: Tue Dec 13, 2011 7:07 pm
Hi kintangoman
There is a constant drip in the pan and when the water level in cistern goes down below the fill watermark on the cistern, about 1/2 inch below this mark, you can here it filling the cistern up again.
I just hoped I could repair/replace it without taking the cistern off the wall and pan?
Thanks for your help
PostPosted: Tue Dec 13, 2011 8:32 pm
With the cistern full of water, remove the cistern cover, then use a cup or similar and remove water from cistern so it goes below the 'accepted' fill level mark. Now check if water still leaks into the pan. If it does, then it looks like you have to remove cistern and replace flush/dump valve. If it's not leaking till water fills above fill level, then you need to replace the fill valve.
Long winded, but i'm nackered.
Give it a go & good luck.
Tango.
Users browsing this forum: No registered users and 9 guests
