It is currently Thu Feb 09, 2012 8:08 pm
PostPosted: Sat Feb 06, 2010 11:33 pm
I've bought a house with a conservatory. It appears that the conservatory was simply built on an existing flagstone patio, and is simply resting on the flags. I now have water seeping under the door threshold whenever it rains.
I've spoken to local contractors and specialists, but non-seem to understand the problem, never mind suggest a solution. Maybe I'm not explaining it well enough!
Does anyone here have any ideas???? Hope to hear from someone soon!
 Post subject:
PostPosted: Sat Feb 06, 2010 11:52 pm
Jack Of All Trades
Has thanked: 22 times
Been thanked: 45 times
Some pics would help!.........Are you saying the brickwork was built directly on to the flags?
By eck!
 Post subject:
PostPosted: Sun Feb 07, 2010 3:53 pm
Has thanked: 33 times
Been thanked: 174 times
Hi Karlos,
Shorterm fix is to wait for dry weather and then silicon inside and outside of the threshold, longterm fix is take out the threshold, get a disc cutter and cut a groove about 6mm wide the entire length of the door opening (use a 4inch grinder in the corners) get a piece of waterbar (galvanised length of metal different widths available) grout the waterbar into the groove protruding 10mm up, replace threshold, alternatively, you could have a lead tray made for it.
S
cron
