Page 1 of 1
[ 9 posts ] |
| Author |
Message |
kermit
Posted: Tue May 26, 2009 5:11 pm |
| Newly registered Member |
Joined: Wed Nov 05, 2008 3:47 pm Posts: 13 Has thanked: 1 times Been thanked: 0 times
Hi
I am about to install a 5kw undersink instant water heater.
I was hoping to tie into the ring main with a dp switch, or do I need to wire direct to fuse box with its own breaker?
Cheers
| Top |
Stoday
Posted: Tue May 26, 2009 5:32 pm |
| Deceased 21-10-2011 R.I.P |
Joined: Fri Jan 20, 2006 6:03 pm Posts: 5956 Location: East of England Has thanked: 9 times Been thanked: 93 times
Too much power to add to a ring main. You will have to create a new circuit from the consumer unit.
Do you cook with gas? If you have a spare cooker circuit you could use that.
_________________ I should be dead; I've cheated the Grim Reaper yet again by surviving my third heart attack in June.
| Top |
register or
log in
kermit
Posted: Tue May 26, 2009 10:06 pm |
Thanks for help.
Out of interest, if I was to install 2 units same power would they both need their own circuit?
| Top |
register or
log in
markysparky
Posted: Tue May 26, 2009 11:16 pm |
| Electrician |
Joined: Mon Jan 16, 2006 10:02 pm Posts: 272 Location: Darlington Has thanked: 0 times Been thanked: 0 times
It will give recommended fuse rating for each heater. Doubling up on the circuit would mean you would need to protect it with a bigger circuit breaker than it should. So current rating of the fuse would be too big to protect each heater individually.
So answer to your question.. No you couldn't. Each one would need it's own circuit. 20/25 amp 4mm cable is the best probable solution
| Top |
register or
log in
stephenf8542
Posted: Wed May 27, 2009 9:17 am |
| Senior Member |
Joined: Mon Feb 09, 2009 12:14 pm Posts: 142 Location: scotland Has thanked: 0 times Been thanked: 0 times
Why are you asking the same questions on different forums? The answers wont change ,you still cant wire it into the ring no matter how many times you ask!
| Top |
register or
log in
thescruff
Posted: Wed May 27, 2009 9:32 am |
| OAP |
Joined: Mon Mar 10, 2008 12:46 am Posts: 39987 Has thanked: 187 times Been thanked: 2115 times
Lot's of posters post on several forums, especially if they are new to the environment.
You may also have noticed we are having problems with the server, so he may not have been able to get back on.
_________________ If you feel you have benefited from the Free advice given on the Forum, Please consider making a donation to UHM's Nominated charity, read all about it and donate here : donnas-dream-house-charity-t52110.html
| Top |
register or
log in
ban-all-sheds
Posted: Wed May 27, 2009 12:02 pm |
| BANNED |
Joined: Fri Oct 27, 2006 6:40 pm Posts: 418 Has thanked: 0 times Been thanked: 1 times
I'm sorry - I can't come in to work today, the voices are telling me to stay at home and clean the guns.
| Top |
register or
log in
kermit
Posted: Wed May 27, 2009 9:55 pm |
Thanks for those with constructive help, new to forum scene so not sure which site is best or most appropriate, also unaware of rules of only posting on one site!
Once again thanks, have located a water heater circuit and getting electrician in to check spec before installation.
Cheers
| Top |
register or
log in
thescruff
Posted: Wed May 27, 2009 9:59 pm |
| OAP |
You can post on as many forums as you like Kermit
Some are better than others and UHM is probably the best.
| Top |
register or
log in
Page 1 of 1
[ 9 posts ] |
