It is currently Fri May 25, 2012 10:45 pm
 Post subject: Water Hammer
PostPosted: Mon Jan 09, 2012 5:25 pm
Hi.
New user and complete DIY idiot!
I had a leaking toilet pan repaired about a year ago and after everytime we flush the pipes made an horrific noise reminicent of a fog horn!...
Plumber comes and replaces parts inside the toilet - Problem fixed - NO!
Now the toilet no longer does this instead the noise has transfered. If i flush then put on the hot tap then i get the same noise. The washine machine when it hits a certain point in the cycle makes the house shudder!
Air in the pipes? Water Hammer? (i have done a bit of looking on the net)...
Today i bled the air out of the radiator in the bathroom and re pressurised the combi boiler....i then checked the same radiator and for some reason more air came out when i bled it again! Why was there again air in there and is this casuing the problem with the noisy pipes? (i again repressurised the combi). It soesnt seem to have made a differance bleeding the radiator.
Please Help :scratch:
Mat :thumbright:
 Post subject: Re: Water Hammer
PostPosted: Mon Jan 09, 2012 5:41 pm
Has thanked: 4 times
Been thanked: 39 times
:welcomeuhm: The noise is usually due to mains pressure either being arrested suddenly or commonly vibration set up due to a worn ball valve/tap or stop valve washer. Check your main stop valve to ensure it is fully open first to see if that makes a difference.
Central Heating radiators bleeding is a different problem not associated with the above.
PostPosted: Mon Jan 09, 2012 10:43 pm
the main valve under the sink is siezed but i can turn the water off from outside. could that valve being siezed be the issue?
PostPosted: Tue Jan 10, 2012 5:26 pm
Possibly but how did the plumber turn off the water to the toilet? Best have your main stop valve looked at though - you never know when you might need it.
PostPosted: Tue Jan 10, 2012 8:26 pm
all over it mate...getting it sorted...we turned the water off outside when the toilet was fixed.
PostPosted: Wed Jan 11, 2012 11:21 pm
What kind of valve have you got in the cistern? Plastic ones tend to play up more than metal ball valves.
Have you got any mixer taps or similar where the cold mains could be working its way into the hot system?
Users browsing this forum: No registered users and 8 guests
