It is currently Sat Jul 21, 2018 12:46 pm
PostPosted: Tue Sep 19, 2017 2:54 pm
Has thanked: 8 times
Been thanked: 1 times
Hello
Here is what I would like to know if it’s possible.
I have BT Vision. I wish to be able to send the content to another TV in another room
without the need to get another BT YouView box.
The second TV that I wish to send the content to is approx. 20m from the YouView box.
I’m not after anything fanciful and don’t need to be able to remotely change the YouView box
in the other room , just a straightforward piping of the program to another TV.
Appreciate I will need to run a cable between the 2 TV's but want to know what additional
kit I will require. I want a very minimalistic set up and don't want loads of boxes and
plugs required.
Grateful advice etc. I am not technical but a competent DIY'er so no jargon please.
Regards
PostPosted: Tue Sep 19, 2017 5:12 pm
UHM Super Moderator
Has thanked: 176 times
Been thanked: 599 times
I'll move this to general. Likely to get more views there as electrical is generally only looked into by sparks.
For this message the author moderator2 has received gratitude : Froggie56
PostPosted: Tue Sep 19, 2017 5:17 pm
Has thanked: 49 times
Been thanked: 518 times
what box do you have ? what model ? I take it has HDMI only
Edit. A proper active splitter and a 20m HDMI cable should do the trick, A labgear splitter (half decent gear) will set you back £45-£80 (4k 2way splitter)
ie. http://cpc.farnell.com/labgear/hd2-sp2/ ... dp/AV27109
or
go the whole hog with a hdmi over Ethernet (cat5e) and does remotes too for £2-300
For this message the author Bob225 has received gratitude : Froggie56
PostPosted: Tue Sep 19, 2017 5:43 pm
Just read the datasheet
http://www.farnell.com/datasheets/2282944.pdf
there is a optional ir extender kit
eg. https://www.amazon.co.uk/Labgear-HDMI-I ... B005GSZ94S
a dirt cheap option
https://www.amazon.co.uk/iSolem-Switch- ... EK4G7PJ8FW
PostPosted: Wed Sep 20, 2017 9:52 am
Has thanked: 42 times
Been thanked: 547 times
big al would be the one for this??
For this message the author fin has received gratitude : Froggie56
PostPosted: Wed Sep 20, 2017 3:19 pm
Hi All,
Many thanks your contributions and suggestions.
Have subsequently found out the following 2 options would best suit me, and perhaps
anyone else who wishes to do similar
http://www.labgear.co.uk/product-categories/hdmi/hdmi-extenders/labgear-hdmi-60m-extender-single-cat5e6/
or
https://www.amazon.co.uk/dp/B013T5IQH6
Regards to all contributors
PostPosted: Wed Sep 20, 2017 3:44 pm
I didn't see that, but that will work for you, The Neet item looks like a copy of the labgear one
https://www.amazon.co.uk/LABGEAR-HDX60P ... rds=HDX60P
PostPosted: Fri Sep 22, 2017 7:55 am
Hi All
And thank you for your contributions.
May I ask one final question which may seem banal but I have to ask it.
I have BT YouView will this set up enable me not only to watch live progs
via my YouView box (e,g. BT Sport) but recorded pros and progs on catch up
e.g iPlayer on the ‘remote TV’?
In other words will the ‘remote TV’ have exactly the same functionality as if I was watching
the main TV with the YouView Box connected directly.
PostPosted: Fri Sep 22, 2017 3:34 pm
yes you can control the box from either tv, your only splitting the signal and sharing the remote, It may be handy to have a second remote in the other room what can be had off ebay cheaply
