It is currently Wed Jan 17, 2018 3:11 pm
Visit Thermo worx
 Post subject: Waste pipe capped
PostPosted: Sat Oct 28, 2017 5:19 pm
Has thanked: 4 times
Hello,
Thanks in advance for any assistance or suggestions.
My bathroom has developed a bit of an unpleasant sewage smell this morning. I've tried the usual fixes of running water through, but that hasn't made any real difference. Poking around I've found that our waste pipe doesn't vent externally, which was a bit surprising. A bit of googling suggests this is not uncommon if an AAV is fitted.
Looking at what is on top of our pipe, it appears to be made of polystyrene (see attached pic) and doesn't look like any of the pictures I can find of an AAV. Before I start ringing either plumbers or B&Bs, can anyone shed any light on whether this cap is what I'd expect to see or should it be some sort of plastic vented cap?
Cheers
Ad.
File comment: Pic of cap
 Post subject: Re: Waste pipe capped
PostPosted: Sat Oct 28, 2017 6:07 pm
Has thanked: 1357 times
Been thanked: 3505 times
:welcomeuhm:
I'm not a plumber (although I do some plumbing) and is definitely not right. Looks like it needs at the least an AAV.
Air behind water is one of the Plumbers mantras ...
For this message the author wine~o has received gratitude : adman
PostPosted: Sat Oct 28, 2017 6:32 pm
Has thanked: 349 times
Been thanked: 1293 times
Nor me: it also looks like it might have gone out through the roof at one time.
For this message the author ayjay has received gratitude : adman
PostPosted: Sat Oct 28, 2017 6:44 pm
I meant to say that.
PostPosted: Sat Oct 28, 2017 7:01 pm
Thanks, plumber it is then, or maybe the builder as it's been like that since I moved in when it was built 5 years ago. I have a vague recollection of the builders telling me that all the roofs came pre-built and other houses here have pipes that come through to vent externally.
Cheers
Ad
PostPosted: Sat Oct 28, 2017 7:03 pm
Ideally it would vent externally.
PostPosted: Sat Oct 28, 2017 7:07 pm
Has thanked: 97 times
Been thanked: 442 times
I think that foam block is disguising an AAV underneath it. See if you can either lift the foam off or pull the insulation around it down, and take another photo
Cheers,
Darren
For this message the author darrenba has received gratitude : adman
PostPosted: Sat Oct 28, 2017 10:20 pm
Now why didn't I think of that... :oops:
I'm guessing that's an AAV then, is it supposed to have an insulating lump on it?
File comment: AAV
Thanks, back to the drawing board for the source of the niff.
Cheers
Ad.
PostPosted: Sat Oct 28, 2017 11:30 pm
Has thanked: 134 times
Been thanked: 204 times
No, it's not supposed have all that insulation and other crud around it. See you how get on now that it's open and the air can get in properly. If it was blocked or partially blocked there would have been some degree of syphoning which will cause drain smells (often accompanied by gurgling noises from the drain when running taps or flushing loo. etc). If it's still stinky after you've run a bit of water into every trap attached to the stack, the AAAV may be stuck (possibly as a result of being covered in all that loft insulation). It's a fairly straightforward job to replace, either for a plumber or easily DIY-able.
PostPosted: Sun Oct 29, 2017 7:21 am
The foam block on top is fine to put back, just keep the loft insulation away from it.
Quote:
An expanded polystyrene (EPS) insulation cover may be supplied with each OsmaVent 110 valve as an added
protection against extreme high and low temperatures and for outside installations.
Cheers,
Darren
For this message the author darrenba has received gratitude : chrrris
