Ultimate Handyman Home
Washing mahine and water pressure
Post new topic   This topic is locked: you cannot edit posts or make replies.   Thank Post    www.ultimatehandyman.co.uk Forum Index -> General DIY forum
avoman
Junior Member
PostPosted: Mon Jun 09, 2008 7:58 pm    Post subject: Washing mahine and water pressure Add User to Ignore List Reply with quote
Filling question. I have connected both hot and cold supply pipes fo my Indesit washing machine together using a Y adapter from B&Q as sugegsted in an answer to my previous question and connected it to the cold supply. The machine switches on and allows about 5 seconds worth of water in before stopping the flow and emptying. I am assured that the washer was working when I got it second hand. So, could it be a supply pressure problem with the cold pressure being to much for the hot intake (hope this makes sense) and requires a restrictor of some sort or is it just possibly a duff machine? Hope someone can make sense of this question and suggest an answer. Many thanks.
Back to top
thescruff
PostPosted: Mon Jun 09, 2008 8:17 pm    Post subject: Add User to Ignore List Reply with quote
Duff machine.
May be worth getting a guy to check it over, unless one of the guys on here know
Back to top
Hoovie
Devon DIYer
PostPosted: Mon Jun 09, 2008 9:12 pm    Post subject: Add User to Ignore List Reply with quote
if you are on the right lines about the hot intake, you could try a doing a cold fill (think all w/machines have that feature and see what happens then scratch
If you have a son, DO NOT name him after a verb ....
"Which is it, man?"
Back to top
avoman
Junior Member
PostPosted: Tue Jun 10, 2008 7:10 pm    Post subject: Thanks Add User to Ignore List Reply with quote
Thanks, I will give it a go.
Back to top
Display posts from previous:
Post new topic   This topic is locked: you cannot edit posts or make replies.    Thank Post    www.ultimatehandyman.co.uk Forum Index -> General DIY forum All times are GMT
Page 1 of 1
