It is currently Fri Jan 18, 2019 2:11 am
Post new topic Reply to topic  [ 24 posts ]  Go to page 1, 2  Next
 Post subject: Washing machine problems
PostPosted: Tue Jan 23, 2018 5:40 pm
Has thanked: 46 times
Been thanked: 6 times
Might not be the right forum for washing machines but the ones that are only want to sell me stuff... So maybe someone on here can help me.
I have an old washing machine (Bosch WFF 1201) and it has two problems: hot water fill is very slow and all fills are very low level, hardly any water in the machine at all. Been using a hose to fill it and want to try fixing it rather than buying a new one. The second problem (low filling level) I will address some time in the future. First I want to try solve the first problem - slow filling hot water.
I have a gravity boiler but the machine has two filling hoses - red and blue, so I'm guessing the strong cold water pressure can't overpower the hot water as they are separate? Hot water pressure isn't great but I have no problems filling with a hose from the tap. When the filling starts there is a short burst of cold water, then a short burst of hot water but after that hot water just trickles. And after a while it starts "washing" with hardly any water in it. I saw some youtube videos where they tell you to test the valve with a multimeter but I don't have one. But the valve does start and stop the water filling so I'm guessing the problem lies elsewhere? I had the valve taken apart and it's clean so no blockage. It has a metal rod inside which seems to slide up and down just fine. The valve is still working the same after I took it apart so it's not broken (not more broken). I found some second hand ones on ebay which claim to be from working machines but I am hesitant to buy one before I've consulted with someone knowledgeable. Could it be that the operation of the valve depends on high water pressure and because of low hot water pressure it is not staying fully open for long?
Anyway, if any of you guys understand how those things work let me know what the problem might be or what I could do to try to fix it. I'll add a pic of the valves just in case.
Cheers!
PostPosted: Tue Jan 23, 2018 6:02 pm
Has thanked: 39 times
Been thanked: 1406 times
There is such a thing as a low pressure valve, for use when the water pressure is low.
How ever you should test it first.
As you have figured out how to get the valve apart, why not take the valve out, reconnect it to the inlet hose and secure it over a bucket (not in the bucket) restore mains, switch on and see what happens.
Low fill level is caused by blocked pressure chamber or problematic pressure switch. I would look at the pressure chamber and its outlet, i bet its all gunked up
PostPosted: Tue Jan 23, 2018 7:04 pm
Hey someone-else,
Thanks for the reply. I did check the pressure chamber and it was clean. There seems to be some adjustment screws on the pressure switch which I'll try adjusting. But first I want to deal with the hot water valve. Will try switching the machine on with the valve out as you suggested. Will get back with the results tomorrow.
Cheers
PostPosted: Tue Jan 23, 2018 7:18 pm
NO! don't touch the screws on the pressure switch!!!!!
The other thing is the pipe from the pressure chamber to the pressure switch they some times get whole in them due to being rubbed in the spin vibrations.
Take the pipe off hold one end closed and blow down it, it should be hard to do, or you could just look for a warn bit.
PostPosted: Tue Jan 23, 2018 7:39 pm
Not going to be the pressure switch hose. It's a sort of star-shaped hose and the points keep it from rubbing through. I did blow into the pressure switch through that hose and could hear a two-stage click. Did not notice a pressure leak.
PostPosted: Tue Jan 23, 2018 7:45 pm
Well the only way a WM knows how much water is in it is by the pressure chamber / switch it has to be one of them. Have you taken the pressure chamber off and also looked where it was? it needs to be spotless, want to post a pic?
PostPosted: Tue Jan 23, 2018 8:42 pm
I'll post a pic tomorrow. The chamber was pretty clean. There was a small amount of some sort of salty stuff in there which I cleaned with a toothbrush. And also in the hole where it goes into the drum. Cleaned that too. Could my filling with a hose have messed things up? Like maybe throw out some sort of computer synchronisation if there is such? If there was a pressure leak, wouldn't it just keep filling? I'm just trying to run some scenarios through my head :) That pressure chamber doesn't go very high up, I was thinking maybe it can only fill as high as the chambers top end? I never really paid attention to it when I first moved in so don't really know if it's always been that way... I'll post some pics tomorrow.
PostPosted: Tue Jan 23, 2018 9:45 pm
Pressure chamber works by.............pressure. As water fills the main outer drum, the air in the pressure chamber get compressed, this is detected by the pressure switch. Modern machines dont use much water any way. They used to fill up around 1/3 the way up the door, not any more they don't Adding more water isn't that good an idea since it will take longer to heat it, but it will not do it any harm. Its when the water doesn't stop filling that you have a real problem.
PostPosted: Thu Jun 14, 2018 7:37 pm
Resurrecting this thread as I need a solution to this washing machine problem :smilebox: This project was interrupted by a flu and then other things kept me busy.
I think in my other thread about the hot water inlet valve we determined that the valve is probably okay but low pressure water is having a hard time getting through it. I'll look into a water pump solution later. For now I'm happy to keep filling hot water with a hose.
But I'm not happy about having to keep an eye on the washing machine so I can fill it with cold water every rinse cycle. Hopefully someone (I mean someone-else :lol: ) will help me finish trouble shooting it.
Chances are it is filling as much as it is meant to and there is nothing wrong with it but it's not good enough for me. Not when some of my black items have dry washing powder marks on them after they've dried.
Is there anything we can do to test if it is filling as intended or if it's under-filling? Or maybe hack it (the water level regulator?) so it fills more water for each rinse cycle?
BTW some pics of the pressure chamber as requested earlier.
PostPosted: Thu Jun 14, 2018 7:46 pm
Has thanked: 45 times
Been thanked: 721 times
Get a new machine. You have had it a long time, it's run it's course.
PostPosted: Thu Jun 14, 2018 7:51 pm
How is the new one going to be better? From what I hear they hardly use any water at all.
PostPosted: Thu Jun 14, 2018 8:36 pm
The new one will work and not require you to stand filling it with a hose.
PostPosted: Thu Jun 14, 2018 8:56 pm
I would buy a new one if I new it will fill the amount of water I require. While searching for a solution I saw so many people complaining about their washing machines not filling up enough. I only do one wash a week but I need it washed properly. If I buy a new washing machine and it fills only as much as my current one then I've wasted my money... But if I can't fix this one I'll have to start looking for a new one.
PostPosted: Thu Jun 14, 2018 8:58 pm
I seriously doubt that underfilling is a widespread problem considering how many mooder (ie less than 10 year old) washing machines are in service. If it's really a big issue just add an extra rinse to the cycle, all machines I have owned have that option and I use it a lot when washing my work clothes.
PostPosted: Thu Jun 14, 2018 9:34 pm
I don't know, my friend's new wm washes with little water and when I mentioned it he just shrugged his shoulders. If you look at forum posts where people ask about washing machines that use more water the subject instantly changes to suggestions to use HE washing powder, do smaller loads, use extra rinse setting, etc. It feels like people just don't want to admit that their washing machines are not using enough water and just accept that it is what it is. I'm not like that, I'd go mental if I paid hundreds of pounds for something that isn't performing how I want it to.
