Page 1 of 1
[ 9 posts ] |
| Author |
Message |
EssexBreeze
Posted: Sat Jan 07, 2012 8:44 pm |
| Senior Member |
Joined: Sun Dec 21, 2008 8:27 pm Posts: 111 Has thanked: 0 times Been thanked: 0 times
Hi everybody, I have just fitted a washing machine in my friend's place. Trouble is it is making a massive vibrating noise while running. I did not bother to fix it tightly top to bottom. I can raise it to fit it tight to the front of the worktop but what do I do to fit it to the rest of the worktop as 2inch from the front the worktop is not that thick. Also the machine is at at the end of the worktop and there is a 2 inch gap from the wall. Do I insert a wood wedge between the machine and the wall? The previous machine id not have any wedge. Cheers, James
| Top |
Posted: Sat Jan 07, 2012 9:39 pm |
| Pro Carpenter |
Joined: Sat Dec 16, 2006 10:11 pm Posts: 10527 Location: redhill surrey an auld reekie laddie Has thanked: 134 times Been thanked: 474 times
no the last thing you do is wedge it in tight causes off vibration can be floor or floor covering not firm and hard legs not properly level causing it to rock machine has uneven load or loose /damaged suspension or weight
_________________ we are all ------------------still learning
| Top |
register or
log in
moderator6
Posted: Sat Jan 07, 2012 9:52 pm |
| UHM Super Moderator |
Joined: Mon Aug 08, 2005 10:43 pm Posts: 780 Has thanked: 24 times Been thanked: 63 times
If its new you did remove the transit bolts didn't you?
| Top |
register or
log in
Posted: Sat Jan 07, 2012 11:37 pm |
| Pro Carpenter |
moderator6 wrote: If its new you did remove the transit bolts didn't you? yep that would do it big time
| Top |
register or
log in
nick200
Posted: Sun Jan 08, 2012 9:49 am |
| Senior Member |
Joined: Wed May 05, 2010 2:33 pm Posts: 1918 Location: Oxfordshire Has thanked: 160 times Been thanked: 81 times
From past experience I would say it could be not level, transit brackets, touching something else or something internal like bearings (if old)
_________________ Nick If UHM's helped then please check out UHM's Nominated charity - http://www.donnasdreamhouse.co.uk/
| Top |
register or
log in
EssexBreeze
Posted: Sun Jan 08, 2012 10:36 am |
| Senior Member |
Thanks guys, Sounds silly I guess, but, What is a transit bolt? Cheers, James
_________________ James
| Top |
register or
log in
Posted: Sun Jan 08, 2012 10:45 am |
| Pro Carpenter |
did you unpack the machine ???
the transit bolts are at the back can in a triangular formation can also be 2 or one bolt these stop the drum moving in transit
| Top |
register or
log in
EssexBreeze
Posted: Sun Jan 08, 2012 11:06 am |
| Senior Member |
Cheers big-all, I just looked on you tube. I have not taken them off!! Will do it now! James
| Top |
register or
log in
moggridgeplumbing
Posted: Sun Jan 08, 2012 11:11 am |
| Senior Member |
Joined: Wed Mar 23, 2011 6:54 pm Posts: 388 Location: South London & Surrey Has thanked: 4 times Been thanked: 39 times
Hope you have not damaged the machine running it with transit bolts in! Also ensure the machine is levelled before testing. I assume you didn't bother reading the installation instructions!  Who does!!!!!
| Top |
register or
log in
Page 1 of 1
[ 9 posts ] |
