It is currently Wed Jul 18, 2018 5:47 am
PostPosted: Fri Jul 07, 2017 7:21 pm
Has thanked: 22 times
Been thanked: 12 times
I am replacing a wash basin, the way its plumbed there is no space for pedestal, there is a tiled boxing for hot cold and waste pipes. The current basin is as Armitage 2 tap hole 50cm and and is fixed with the standard wall plug screw and nut plus Armitage bracket just like the one in photo which I think it is specific for the current basin.
Off the shelf wall hung basins are too small designed for space saver cloakrooms. I need 50cm width normal basin to hung on a brick wall. Are there standard wall fixing bracket for basins? Or no such thing!
Ideal_Standard_S915167_Basin_Fixings_MDisplay_BASD.jpg [ 39.35 KiB | Viewed 1542 times ]
PostPosted: Fri Jul 07, 2017 8:12 pm
Been thanked: 5 times
Most modern basins have two large holes at the back to accept these bolts....
http://www.screwfix.com/p/rawlplug-67480-washbasin-fixing-kit/6660f
PostPosted: Fri Jul 07, 2017 8:13 pm
Has thanked: 1452 times
Been thanked: 3725 times
Depends on the wall. Solid or Plasterboard ?
PostPosted: Fri Jul 07, 2017 8:18 pm
Brick wall apparently :mrgreen:
PostPosted: Fri Jul 07, 2017 8:42 pm
Oh yes. should have read the post properly... :oops:
Edit. In which case the product Lloyd 13 links to should be man enough.
PostPosted: Fri Jul 07, 2017 9:51 pm
Has thanked: 147 times
Been thanked: 213 times
Can you still get those metal bracket things that fit one under each side of the basin, and also provide somewhere to hang the towel?
PostPosted: Sat Jul 08, 2017 10:02 am
Yes it is brick wall and its tiled. Are the raw plug basin kit strong enough?
They are just under 15kg in weight.
PostPosted: Sat Jul 08, 2017 12:07 pm
I've hung a lot of basins on those bolts never had an issue, you can always put some no nails on the back of the basin before mounting it. Long as your not planning to change it again anytime soon!!
PostPosted: Sat Jul 08, 2017 12:30 pm
Thank you all for replies.
I will be using wash basin raw plug fixing set as said here plus basin mounting bracket as in the photo for safety.
Cheers
PostPosted: Sat Jul 15, 2017 11:27 am
Just got my basin parts but the wall fixing kit, shall I go for 10mm or 8mm fixing kit? I am thinking 10mm is stronger.
PostPosted: Sat Jul 15, 2017 1:57 pm
Yes Lloyd13 link of SF is 10mm, cheers
