Filling in screw holes in ceiling
jc1231
Has thanked: 5 times
Been thanked: 1 time
Post by jc1231 »
I wasn't certain where this should go, so apologies if it's in the wrong place.
I've removed a kitchen blind, and there are some small holes where it was screwed in. What's the simplest way/product to fill those in? Thanks.
Cannyfixit
Has thanked: 86 times
Been thanked: 160 times
Post by Cannyfixit »
Small tube of ready mixed poly filler from B&Q
You will need to remove any rawl plugs that are still in the holes you can do this by putting the screw back in and pull it out
Once dry a light sandpaper then paint with you chosen colour
These users thanked the author Cannyfixit for the post:
jc1231 (Fri Nov 08, 2019 1:11 pm)
ahfix
Has thanked: 12 times
Been thanked: 90 times
Post by ahfix »
If it's just screw holes then fine surface filler from Screwfix will do the job.
ah
These users thanked the author ahfix for the post:
jc1231
Post by jc1231 »
Thanks, both. And thanks ahfix for the link :thumbleft:
Return to “General DIY forum”
