Kodak Printer
- Has thanked: 1 time
- Been thanked: 2 times
Kodak Printer
Hi, I have been given a Kodak printer which I am assured is in working order but it's power lead is missing. Manual says only use Switching Adapter 36v DC @ 0.9A supplied. The printer is a Kodak ESP C310. I will have to have a look on Ebay for one but am I limited exactly to that model and rating. Not very tech savvy so hope you understand . Thanks
- etaf
- Has thanked: 37 times
- Been thanked: 137 times
Kodak Printer
are you 100% certain it works, seen quite a few kodaks of that model stop working, in fact we had a couple of years ago and it stopped.
you will need the correct voltage 36V DC , if that is what it says it needs - 0.9A can be rated higher on the adapter - Not lower
Simple DIYer
Wayne
Wayne
- Someone-Else
- Has thanked: 42 times
- Been thanked: 2481 times
Kodak Printer
You have been given a printer that you are told works, but how could it if it does not have a power supply?
You have to spend money on a power supply for a printer that may or may not work that will probably need more ink.
To be honest, its probably going to cost more than a new printer will to fix / get parts.
I do not know how good it is, but you can get an all in one (brand new) for £25 click here
- big-all
- Pro Carpenter
- Has thanked: 731 times
- Been thanked: 2304 times
Kodak Printer
i would never ever buy a "cheap printer" they are cheap to tie you in to overpriced cartridges
even when you can get generic they can often be "chipped " to stop things working
if its cheap then make sure 100% it can be definatly bypassed to use generic cartridges
- Has thanked: 774 times
- Been thanked: 3308 times
Kodak Printer
I had a Kodak printer and I would have given it away too. It was cartridge hungry and even though they made a thing about the cost of the cartridges being cheap (not that cheap)you can not refill them as there is an electronic chip in the cartridge that once set to empty cannot be reset. I dumped mine and got an HP Deskjet which was on offer in Tesco for £20.
My advice is do not spend any money on it, dump it.
- Someone-Else
Kodak Printer
But isn't that the same with which ever brand of printer?
- ayjay
- Has thanked: 458 times
- Been thanked: 1708 times
Kodak Printer
I've got a Canon printer (TS5050) which was about £60 when new, I can get a full set of 5 compatible cartridges for £12.99, (5 as it has a photo black as well as a print black).someone-else wrote: ↑Wed Oct 30, 2019 11:27 pm But isn't that the same with which ever brand of printer?
I would say, don't buy an Epson, my last printer was an Epson, again, I could get cartridges cheap, but the printer clogs up with ink if it's not used regularly, and the built in cleaning programme makes it worse by chucking more ink on top of the clogged up ink in the hope that it will somehow disappear.
- big-all
- Pro Carpenter
Kodak Printer
yes thats the pointsomeone-else wrote: ↑Wed Oct 30, 2019 11:27 pmBut isn't that the same with which ever brand of printer?
thats why i say check the running costs over a few years rather than upfront in isolation
