Pipes, Joists & Floorboards
- big-all
- Pro Carpenter
- Has thanked: 731 times
- Been thanked: 2303 times
if you have a router /table saw pull saw [trenching ] circular saw then bracket thickness plus 2mm slot are ideal but leaving 17mm minimum meat in the plank to allow the use off 5/8th screws in the plates or brackets without broaching the surface
