How to get TV sound without a TV?
- APDIY
- Has thanked: 193 times
- Been thanked: 11 times
There are times when I'm DIY-ing (Inside and outside my home) when I'd like to be able to listen to the sound on TV and don't need to watch. Like a portable radio - even if it does need a mains elec supply.
Is there a way of doing this short of lugging around a portable TV, please?
- Has thanked: 66 times
- Been thanked: 788 times
Its called radio, sound without moving pictures
Back in the days of analogue TV it was possible, now its all digital it's not as easy as the signal needs to be decoded, A Bluetooth radio or Bluetooth speaker and a smart phone may be a option then you can stream any service you like, play podcasts or even an audio book
- Has thanked: 63 times
- Been thanked: 915 times
If you can get wifi then you can watch/listen to live broadcasts on your phone.
- big-all
- Pro Carpenter
- Has thanked: 662 times
- Been thanked: 2029 times
baby monitor near the tv
- APDIY
Thank you, Rorschach.
Yes, I have wifi.
Would that 'come off' my data allowance? I use GiffGaff @£6/month and have a low Data allocation as I hardly ever, use that facility.
- APDIY
Thanks - I can remember when they were called Wireless and my father had a long piece of wire stretching down the garden as an aerial.
From the reading I've done - and what I could understand, as you say the change to Digital has made matters very complicated - especially for a complete novice.
Is that data allowance on your mobile phone plan or on your home internet package?
- Someone-Else
- Has thanked: 22 times
- Been thanked: 1861 times
GifGaf supply sim cards, so I guess its his mobile phone
Are you going to be working on anything electrical? have you got a multi meter? why not? Would you hit a nail with a shoe because you don't have a hammer?
How to post a picture on this forum Click here (Pending update)
Video of how to resize / rotate pictures can be found on This page
- ericmark
- Has thanked: 80 times
- Been thanked: 672 times
It's called a set top box, not that they are put on top of a TV any more, but all mine have phono outputs the problem is knowing what channel you have tuned into, but my IceCrypt box you can change the order to suit what you want, I often listen to radio on satellite as FM and freeview in this area is useless.
- APDIY
Yes, GiffGaff is the clue - my limited Data ration is on my CellPhone.
@ ericmark - my searches online have taken me time and again to Webpages from USA - and from what I can understand they use what we call a Set Top Box to do what I want to do.
If I get it right those boxes converted the Digital signal to Analogue to cater for 'old' analogue TVs. I've got a couple of those boxes sitting around.
Can I then follow your route Bob225 » Fri Oct 04, 2019 10:44 am ?
If so, what do I have to do, please?
If you find a set top box (STB) with scart or even spdif you can take the audio to an amplifier or bluetooth adapter
- APDIY
T Y for that, Bob225.
Yes, I have a couple of STBs which have scart ports and some scart leads.
Have you any suggestions as to which bluetooth adapter to look out for?
Regards
