Beeline yellow top
chilli76
Has thanked: 1 time
Been thanked: 1 time
Beeline yellow top
Post by chilli76 »
Hi, can Beeline Yellow top be used on non woven wallpaper and if so what would the dilution rate be?
Cheers
Have Brush Will Travel
Has thanked: 224 times
Been thanked: 384 times
Beeline yellow top
Post by Have Brush Will Travel »
It would be fine...check the tub for dilution rates..
These users thanked the author Have Brush Will Travel for the post:
chilli76 (Sun Sep 22, 2019 8:59 pm)
chilli76
Has thanked: 1 time
Beeline yellow top
Post by chilli76 »
Have Brush Will Travel wrote:
Fri Sep 20, 2019 9:20 pm
Cheers, what would you class non woven as with regards mixing paste, lightweight vinyls, wahable and lining paper or heavy weight papers? these are the dilution rate options on the tub. Thanks again
Beeline yellow top
I would class is as a lightweight vinyl...might be an idea to do a test first..cut a couple of 500mm lengths, dont worry about matching them.. paste the wall and apply them and allow to dry, then check the joints to make sure they haven't shrunk (which they shouldn't)
When you paste the wall, put the paste on with a medium pile roller..slightly heavier than what you would with paint...but not excessive
