Moved into a new flat and have repainted the living room walls. Originally the walls were deep blue colour but we decided to repaint it cream/white. It required 3 layers of white matt emulsion to completely hide the blue and then we finished with 2 layers of the cream topcoat.
This is the end result
[img][/img
The walls look extremely streaky/patchy from certain angles however the streaks disappear when you face the wall directly. Was wondering if anyone else has had this problem before and how this can be fixed?
Painting wall
- wine~o
- Has thanked: 1413 times
- Been thanked: 3988 times
Painting wall
assuming you have used a trade emulsion then the only things that would cause what you describe is poor technique or a poor substrate.
Keep the roller evenly loaded, keep a wet edge and roller in a "W" shape to get the paint on then up and down ... the final stroke of the roller should always be in the same direction (top to bottom/ bottom to top whichever you find easier)
