Hi All
I could really use a little help, please.
I just started using the Leyland trade water-based satin, but I am having a few issues.
I am painting the skirts and door frames, but I am finding that the brush ( hamilton trade) is clogging up very quickly, and leaving really thick brush marks.
The skirts and frames have all been undercoated & rubbed down, but it is not going on very well.
any help gratefully accepted.....
Rob
leyland water based satin.
- Has thanked: 27 times
- Been thanked: 3 times
- Has thanked: 855 times
- Been thanked: 994 times
Don't know the particular brush or paint but ... that is a synthetic brush yes (does not have black bristles)?
- crown trade (paints) recommend(ed) that you wet the brush before you start. Dip it in water, make sure all filaments are wet and then shake off excess water. You may have to wash the brush many times through the day (every hour or two?)
- keep the house as cool as possible from before you start painting
- I would use a paint kettle and only have a little of the paint there so you don't have the whole container drying up.
Other than the above, to avoid brush marks don't waste time when painting and fidgeting with small things, do not go back where you painted even if it is 5 minutes since you went over an area, if you must you can prewet the surface with a damp sponge or cloth but you should not need that for skirtings and door frames.
If it helps a little.
Many thanks for the reply OchAye.
have purchased a new paint kettle, and will do as above the next time I paint the skirts. Which will be this weekend.
Hopefully, it will go on a little better...
Regards Rob.
Regards Rob.
- wine~o
- Has thanked: 1413 times
- Been thanked: 3988 times
Synthetic brush every time with water based. also can help to dip the brush in water before starting and occasionally throughout the job to prevent dragging.
- Andrew
- Has thanked: 3 times
I've had the same issues (visible brush strokes) with Armstead quick dry satin. Literally the worst paint I've ever used. Tried all the tricks yet it gives a horrendous finish. Dries in seconds.
I knew I should have stuck with Johnstones aqua gloss.
Does anyone know whether I would be okay to use the Armstead quick dry primer / undercoat with Johnstones water based top coats? I can't see why not?
- Has thanked: 774 times
- Been thanked: 3308 times
Johnstones seems to stick to anything I have found. As long as it is clean and keyed it goes on fine. I had to paint over a small bit of glossed skirting and I could not be arsed to get the undercoat out so I rubbed it down with some wet and dry, dried it off with some kitchen paper and went straight on with Aqua gloss. It stuck all right and still looks good. I do not think you will have problem with the Amstrad.
