Just looking through the new Brewers deals - they advertise Johnstone's StainAway Matt - One coat stain blocking for smoke,nicotine and water stains. This StainAway Matt is WATER BASED Anyone used it?
- wine~o
- Has thanked: 1413 times
- Been thanked: 3985 times
Never used it, Bear in mind that any water based stain block (Zinsser or others) are just that stain blocks...
They just lock the stain in , they do not cover the stain. (A lot of people make this mistake and then complain that it didn't cover the stain)
You will still need to re-coat with emulsion or whatever after using a stain block.
- Has thanked: 1 time
- Been thanked: 1 time
Hi, I have used Johnstone's stain away on a number of occasions. The first was to cover a yellow nicotine stained ceiling, covered in 2 coats to a brilliant white (must leave a minimum of 4 hours between coats.
The second was to cover water damage on the ceiling and wall, again two coats required but what a great finish.
Easy to apply, easy to clean up equipment, very little smell, a great white finish just a little expensive.
