Hi
What is the rough cost of having a velux window fitted in a loft (it's not habitable, it's used for storage)?
It's a two floor terraced Victorian house.
Can it be installed without scaffolding?
Sent from my Nexus 5X using Tapatalk
Cost of installing a velux window
- Has thanked: 61 times
- Been thanked: 184 times
Re: Cost of installing a velux window
I'm trying to get a couple installed in my upstairs (my house is a 1 & 1/2 story). If no timbers need to be cut then you are looking at a days work, work can be done from the inside. If timbers need to be doubled and cut you are maybe looking at 2 days.sammy.se wrote:Hi
All I can say is don't call a roofer ... I have had a couple out but they will not do any alterations (but won't tell you that up front), find a good joiner and have a chat.
ah
Depends on the roof construction, if your roof is: felt, cross battens then tile, you can cut the felt in the middle of the opening and remove a few tiles, enough for you to pop your head through. If the roof has sarking boards it might be a bit more of a challenge but still possible. Otherwise a long ladder to clear the tiles for the opening but do the actual install of the velux from the inside.sammy.se wrote:Thanks ahfix.
I'm curious as to how they remove the roof tiles from the inside?
ah
