kevinsmbuk wrote:Thanks for the information. So the long as short of it I am looking at a full rewire at some point!
Because of the green goo, yes.
Wagos are MF. However you could not use them to join two cables and just bury it in plaster.Argyll wrote:Wago's are great but personally I'd crimp and heatshrink and cover the single socket with plaster. No point having a blank plate in the wall if there's no need. Particularly if you wish to have higher skirting boards and the blank plate would obstruct that which happened in my case.
I understand wago's would be the quicker option but there's mixed messages whether they are maintenance free (MF) or not so you can't bury them.
I'm not an electrician so maybe an electrician would confirm if wago's are MF or not.
It's the degredation of the placticiser in the PVC coating.someone-else wrote:If you have green goo, that is the cable starting to breakdownkevinsmbuk wrote: (it's a 60's house with green goo type outer sheathing!)
