I've used Zinssers Wallpaper Cover Up to prime some vinyl wallpaper (intending to put emulsion over it). The Zinssers has done a brilliant job of adhering to the vinyl, but I think the walls would benefit from a layer of lining-paper before painting. I know I'm a terrible person for considering this .
Will Wallrock Fibreliner (using Wallrock Power Adhesive) adhere to the Zinssers Wallpaper Cover Up? Or will it'll need a coat of emulsion first?
Thanks,
Jim
PS. The vinyl wallpaper was simply too well stuck. Nothing would shift it apart from a chisel.
Paper over Zinsser Wallpaper Cover Up?
- Tom d'Angler
- Has thanked: 1112 times
- Been thanked: 548 times
Re: Paper over Zinsser Wallpaper Cover Up?
Wallpaper Cover Up is an excellent product. One of its benefits is that it will provide a good surface for emulsion to stick to so I don't see any reason why lining paper wouldn't stick to it. It wouldn't do any harm, and wouldn't take long, to size the walls first.
Why do you think you need to line the walls?
- Have Brush Will Travel
- Has thanked: 224 times
- Been thanked: 384 times
It should be ok..but I would do a test piece first
The surface of the vinyl should have peeled from the backing paper easy..
- Has thanked: 18 times
- Been thanked: 15 times
A waste of Zinserr wallpaper cover up me thinks, should have just stripped the paper off and lined your walls.
