If I am adding a floorplate then I will need to adjust/remove the wood battons to compensate.
Good point about the track being fitted to the floorboards, I hadn't considered that. I was more thinking about whether the carpet would look wierd being curled over to match the floor track which is only about 8-10mm tall!
dewaltdisney wrote:It levels it up and keeps it even if the track is fixed to a floor plate. In your plan it will depend on the floor to ceiling gap and the doors you intend to use. It is easier to sort the gap out with a floor plate with shims to get it level and spaced right. A track fitted to floorboards might flex and derail the doors?
