Threshold boards
- mole81
- Has thanked: 39 times
- Been thanked: 4 times
Threshold boards
Excuse the sapilli doors... Has anyone ever seen these wooden monstrosities before? I want to remove them all but am concerned about the flooring gap it will leave. Will I also need to replace the door stops too?
Sent from my SM-G930F using Tapatalk
- kevinsmbuk
- Has thanked: 212 times
- Been thanked: 27 times
Re: Threshold boards
Yes, I am removing mine, had done a couple already, they are nailed to the floorboards and go under the door jambs generally. Best thing to do is if you have a multicutter, cut through the middle then pull each part up separately. Your issue is that you are going to leave a pretty big gap! normal door thresholds are alot thinner so it's the sort of thing you remove before laying carpet and the carpet fits up to the silver/gold style threshold.mole81 wrote:Excuse the sapilli doors... Has anyone ever seen these wooden monstrosities before? I want to remove them all but am concerned about the flooring gap it will leave. Will I also need to replace the door stops too?
- mole81
Do you have to replace the jams too? :okevinsmbuk wrote:Yes, I am removing mine, had done a couple already, they are nailed to the floorboards and go under the door jambs generally. Best thing to do is if you have a multicutter, cut through the middle then pull each part up separately. Your issue is that you are going to leave a pretty big gap! normal door thresholds are alot thinner so it's the sort of thing you remove before laying carpet and the carpet fits up to the silver/gold style threshold.mole81 wrote:Excuse the sapilli doors... Has anyone ever seen these wooden monstrosities before? I want to remove them all but am concerned about the flooring gap it will leave. Will I also need to replace the door stops too?
- kevinsmbuk
- kevinsmbuk
Removing completely, although you could cut around the jambs. Not sure why you would thoughmole81 wrote:So are you removing it completely where it goes under the jamb? Or cutting it flush?kevinsmbuk wrote:No
Sent from my SM-G950F using Tapatalk
- mole81
Sorry for all questions.. What are you doing about the gap where it went under the jamb?kevinsmbuk wrote:Removing completely, although you could cut around the jambs. Not sure why you would thoughmole81 wrote:So are you removing it completely where it goes under the jamb? Or cutting it flush?kevinsmbuk wrote:No
- kevinsmbuk
The new carpet on the right will sit under door jumb to hide the gap, if a little gap shows its not the end of the worldmole81 wrote:Sorry for all questions.. What are you doing about the gap where it went under the jamb?kevinsmbuk wrote:Removing completely, although you could cut around the jambs. Not sure why you would thoughmole81 wrote:So are you removing it completely where it goes under the jamb? Or cutting it flush?kevinsmbuk wrote:No
- kevinsmbuk
Here's another room, same thing just not removed yet.
- mole81
I see what you mean looks tidy, thanks for your help. Need new flooring now lolkevinsmbuk wrote:The new carpet on the right will sit under door jumb to hide the gap, if a little gap shows its not the end of the worldmole81 wrote:Sorry for all questions.. What are you doing about the gap where it went under the jamb?kevinsmbuk wrote:Removing completely, although you could cut around the jambs. Not sure why you would thoughmole81 wrote:So are you removing it completely where it goes under the jamb? Or cutting it flush?kevinsmbuk wrote:No
- kevinsmbuk
Haha no problem, well it will look tidy when sorted!!mole81 wrote:I see what you mean looks tidy, thanks for your help. Need new flooring now lolkevinsmbuk wrote:The new carpet on the right will sit under door jumb to hide the gap, if a little gap shows its not the end of the worldmole81 wrote:Sorry for all questions.. What are you doing about the gap where it went under the jamb?kevinsmbuk wrote:Removing completely, although you could cut around the jambs. Not sure why you would thoughmole81 wrote:So are you removing it completely where it goes under the jamb? Or cutting it flush?kevinsmbuk wrote:No
