I live in a 30s semi with solid brick walls, which are pebbledashed and painted, There is some water penetration. To overcome this, I need to know my options, please.
Do I Repaint the existing surface; Strip the pebbledash and replace with smooth screed or wallcoating; etc?
Damp in external walls
- Has thanked: 3 times
- Been thanked: 91 times
Re: Damp in external walls
you could try a waterproofer first if you dont want to re-coat
http://bit.ly/2uVltRf
Thomsons water seal is not as good as this stuff, hence why its much more expensive.
Assuming it is water penetration caused by porous walls? Check guttering, DPC etc
- Has thanked: 1 time
Thank you, Notch1
I'll look into that. The existing pebbledash looks well past its prime so for cosmetic reasons as well as damp-proofing, I will still need to re-coat either with masonry paint or go the whole hog and replace the pebbledash with a resin finish.
