Best kind of lubricant for door
- Has thanked: 34 times
- Been thanked: 3 times
Had new doors fitted for the house and the installer said for maintenance I should lubricate the metal locking points in the frame about once a month. I asked him what kind of lubricant and he said WD40.
Is this really the best thing to use or should I be using something else? People who use WD40 on their bicycle chain will seem like it's lubricated but it will eventually pick up dirt and dust and then turn into a nasty, gunky mess. I don't want the same thing to happen to my door.
Suggestions?
Suggestions?
- Argyll
- Has thanked: 1168 times
- Been thanked: 571 times
Re: Best kind of lubricant for door
WD-40 is a degreaser and is not suitable for lubricating hinges. I normally use a standard 3in1 oil or white lithium grease (spray can) from Screwfix.
http://www.screwfix.com/p/wd-40-special ... _container
- Has thanked: 99 times
- Been thanked: 1022 times
- steviejoiner74
- Has thanked: 747 times
- Been thanked: 1616 times
I use silicone spray,works great. Never use wd40 and never use graphite powder on a lock either.
- wine~o
- Has thanked: 1413 times
- Been thanked: 3988 times
Nothing wrong with WD40 ( on hinges or on multi - point locking systems ). once the water dispersant has evaporated off it just leaves a film of oil behind.
Agree that it shouldn't be used on the actual lock though (The part that you put the key in..just to be clear.).
- steviejoiner74
It doesn't leave a film of oil behind it washes/cleans away any oil/lubricant that's been put on in the factory and it'll be smooth as silk for a few weeks but then it attracts all the dust and dirt which clings to the mechanism and more wd40 is applied and the problem will slowly get worse.wine~o wrote:Nothing wrong with WD40 ( on hinges or on multi - point locking systems ). once the water dispersant has evaporated off it just leaves a film of oil behind.
Wd40 is the single biggest problem that causes locks and mechanisms to have problems,every call back we've ever had back on patio doors,French doors or front/back doors has been due to the customer flooding the mechanisms and locks with wd40 and they get gunged up with crap.
- wine~o
Like I said no good for locks. Fine for hinges.steviejoiner74 wrote: and locks with wd40 and they get gunged up with crap.
Edit http://www.wd40.co.uk/ see "Lubricates"
- steviejoiner74
You said multi point locks as well....wine~o wrote:Like I said no good for locks. Fine for hinges.steviejoiner74 wrote: and locks with wd40 and they get gunged up with crap.
