Oven tripping Rcd
- Has thanked: 12 times
Oven tripping Rcd
I have a 2 month old electric fan oven . For the last couple of days it's been tripping the Rcd. Have narrowed it down to it being when the oven reaches whatever temperature I set it at.so it's fine when it's in the process of getting to temp but as soon as its hits temp it's off.
Wouldn't be too bad if it just knocked the oven off but it's down sockets and up lights too( disturbs my sky recordings!) it will reset straight when it's cooled a bit but off again when at temp.. It could be set at 100 degrees or 250.
Is it more likely to be oven..ie thermostat or element or electrical fault?
- wine~o
- Has thanked: 1413 times
- Been thanked: 3988 times
Re: Oven tripping Rcd
If it's the rcd tripping then I would suggest that the oven is faulty...
Assuming that the oven has been installed correctly..
- nick200
- Has thanked: 409 times
- Been thanked: 222 times
Who hard wired it in? I would leave it but check if the RCD is ok for the cooker.
If RCD is ok, then it is only two months Old and I would speak to manufacturer/seller of the cooker.
Just remembered that ours did this but it was sorted by them replacing the cooker RCD as it was faulty. It is a long shot.
Nick
We used the guy that installed the kitchen a few years ago.would have done it myself but couldn't hold oven I right position and connect it at same time..
We had a new circuit board installed last year .. How can I check the RCD or is it a get a man in kind of job? Will double check all wires are ok tomorrow .
- Approved Electrician
- Has thanked: 222 times
- Been thanked: 656 times
You can eliminate the element (a faulty element would trip the RCD as soon as heat is called for)mrscb wrote:That's the answer I was hoping for IYKWIM
Thanks..
The oven is hard wired in..would it be worth taking it out (it's built in) and trying it with a plug .?
You can eliminate the fixed wiring (the RCD would trip as soon as heat was called for)
- wine~o
As it trips when up to temperature, most likely would be an issue with the thermostat........OnlyMe wrote:You can eliminate the element (a faulty element would trip the RCD as soon as heat is called for)mrscb wrote:That's the answer I was hoping for IYKWIM
Thanks..
- wine~o
mrscb wrote:Contacted oven company , they are sending out engineer on Monday. Slow cooker meals and takeaways for the next few days:-(
What No hob?? or is it a combined oven and Hob.. ??
I'm doing duck breasts with a Port and red wine reduction, Lyonnaise potatoes, carrots and green beans...
Just thought I'd share....
