Hi all,
I have some projects in mind ("craft" projects, not building projects) for which Quikrete would be ideal. However I see Quikrete isn't available in the UK. Can anybody recommend a good quality, reasonably fine ready-mixed concrete available in the UK?
thanks!
James
UK alternative to QUIKRETE?
- ayjay
- Has thanked: 458 times
- Been thanked: 1708 times
Re: UK alternative to QUIKRETE?
Ready mixed concrete will be delivered by the cubic yard, that sounds like an awful lot for a, "Craft project - not a building project".
You can buy *Prompt Cement* which can be mixed with sand or aggregate to achieve a quick set.
*Ciment Fondu* is a similar product often used for Craft projects.
http://www.cornishlime.co.uk/promptcement.php
http://www.bathpotters.co.uk/ciment-fondue/p524
- Has thanked: 1 time
Hi ayjay --- I might have used the wrong terminology --- is "ready mixed" the sort that comes in a truck? I meant the dry mix that comes in a bag. The options you propose look like they're worth investigating, thanks for the advice. Aesthetically, what is the difference between concrete and cement? Will the cement you recommend set to look pretty much like concrete? (I know the final look of concrete will also depend on what binding materials you add, but still.) We like the aesthetic of concrete, and I'm a bit wooly on the differences of the finished product....
J
J
- ayjay
Concrete is the term usually used for a mix of cement sand and aggregate (stones).
"Ready-mix" is what we usually call concrete delivered by a mixer lorry - (in fairly large quantities).
Cement is the powder which is added to sand or aggregates to make them go hard, it's very rarely used on its own, the sand and aggregate can be used in various proportions depending on what you want it to do - usual mixes will be somewhere between 1 - 3 (cement to sand - very strong) and 1- 6.
You can replace some or all of the cement with *prompt cement* or *ciment fondu* to achieve a quicker set.
You can buy a product called *Postcrete* which is a dry concrete mix in bags, it's intended for fixing fence posts but could be used for other projects - it's quicker drying than a standard concrete mix.
- FFX
- Has thanked: 6 times
- Been thanked: 37 times
Everbuild do a product called Jetcem (some might call it JetMix) - which is a premixed bag of cement and sand which sets in about 30 min. It comes in different size bags between 2-6kg.
Regards
FFX
Regards
FFX
