Seems that way. The cable from it is only a 2 wired cable.thescruff wrote:Does that mean the boiler hasn't got an earth. ?
How to install a Room Thermostat on my condensing boiler.
- Has thanked: 7 times
Re: How to install a Room Thermostat on my condensing boiler
- thescruff
- Has thanked: 360 times
- Been thanked: 3734 times
Would have been nice to give it one whilst you're at it.
How would I do that ?thescruff wrote:Would have been nice to give it one whilst you're at it.
I take it that it meant having to open up the boiler casing to get at the circuit board in the boiler and run a earth from there to the stat and connect up the mains 3 pin plug earth ?
- thescruff
That's right, it will mean opening the wiring centre/ control panel on the bottom.
It would give you the chance to re-position the receiver.
That's too much work :)thescruff wrote:That's right, it will mean opening the wiring centre/ control panel on the bottom.
So long as the current setup will not harm the new stat, I'. happy with it as it is. Never feel comfortable playing with gas apparatus !
Quick question.thescruff wrote:Ok can the receiver go where the old timer is.
Connect the plug wires blue to N and brown to L.
Connect the brown in 1 to B.
Connect the blue in 2 to N.
Link L to A
If there's a docking post for the earth stick the wire in it otherwise make it safe.
I am in the process of connecting this up. But why is there a need to link L to A when A is not used in the wiring ?
- thescruff
Depending on which model it will be something like this.
- eclat-02-09-12.jpg (53.78 KiB) Viewed 3362 times
- thescruff
Exactly as I wrote it please.eclat wrote:Quick question.thescruff wrote:Ok can the receiver go where the old timer is.
Link L to A
A is com, and put power on B when calling.
ok, thanks. Just curious and wondering.thescruff wrote:Exactly as I wrote it please.eclat wrote:Quick question.thescruff wrote:Ok can the receiver go where the old timer is.
Link L to A
UPDATE:
Just thought I'd let you know that I've just completed the installation. Took a bit longer than expected. Had difficulties fitting 2 wires (boiler + mains) into the small screw connector on the stat. But got there finally and everything seems to be working well.
Thank you all for your help, and especially to thescruff. You're the greatest !! :) Take care !
- thescruff
Well done.
The live has two connections you can use, the neutral you could have used a small connector block.
Can I go and play snooker now
24 hour till we start the defence of our title.
Good luck to the defence of your title. Stay well.thescruff wrote:Well done.
UPDATE QUESTION
I just noticed that the pump and the pipe near it is warm even though everything is switched off at the mains. Only the pilot light is on in the boiler. Is this normal as I have never noticed this before as there was no reason for me to hang around this part of the boiler in the past ?
Thanks for the clarification.
- thescruff
It's normal if the boiler has come on, otherwise it needs investigating.
Explain switched of at the mains.
Where is the pump in relation to the boiler, could it be residual heat from when you tried it yesterday.
It's best not to turn the plug off on the stat, instead turn the htg off on the stat
I only turned on the boiler for about 3 times for aboyut 4 minutes each time yesterday to test that the CM927 installation works after I installed it. Then everything is switched off and the stat relay is unplugged from the mains 3 pin plug. So the boiler is not getting any electrical supply for it fired up even though the pilot light is left on. The on/off switch on the boiler is also set to the off position.thescruff wrote:It's normal if the boiler has come on, otherwise it needs investigating.
Surely the residual heat from yesterday could have have still be around after over 12 hours ? I thought the heat could have been from the pilot light ? That would be the only source of heat nearby
The pump is just above the boiler, about 6 inches above it.
