Screws for use in the shower
helenm
Post by helenm »
Ok, call me a dumb blonde (I'm not!) but can someone please tell me which type of screws to use in my shower cubicle to fit a tray to the wall?
I completed this DIY job a couple of months ago but the screws are now rusted and I only just managed to remove them! Is there a special type of screw to use that won't rust? The deckscrews I have seen are too wide and too long!
Helen
Has thanked: 999 times
Been thanked: 915 times
Post by ultimatehandyman »
Hi Helen, welcome to UHM :hello2:
Ideally you need stainless steel screws for in a shower area.
You can see some here-
http://www.screwfix.com/app/sfd/cat/cat ... 7&ts=83848
Jaeger_S2k
Pro Handyman
Has thanked: 20 times
Been thanked: 27 times
Post by Jaeger_S2k »
Hello Helen,
You Dumb Blonde, there.
For the shower rusting problem, Image
Jaeger.
Hitch
Has thanked: 77 times
Been thanked: 335 times
Post by Hitch »
Stainless steel screws will be the best bet. :thumbright:
Hinton Heating
Gas/Heating Expert
Been thanked: 9 times
Post by Hinton Heating »
how about brass screws???
Hinton Heating wrote:how about brass screws???
Not keen on brass as normally you have to use a flat screwdriver and they still oxidise eventually and I guess this would be made worse by the chemicals in use in the shower.
Hitch
Post by Hitch »
Brass tends to discolour and go black over time doesnt it.
helenm
Post by helenm »
Thanks guys!
I suppose that the stainless steel screws for "outdoor use" don't necessarily mean they are soley for outdoor use then...just that they aren't likely to rust when exposed to water?
Helen
Hitch
Post by Hitch »
Stainless ones wont rust-
The A2 grade basically means they are resistant to normal wet conditions and most chemicals. Perfect for a shower. :thumbright:
A4 grade ones would be better if you showered in sea water, or nasty chemicals..... which i doubt you do either :lol:
helenm
Post by helenm »
You've obviously don't know anything about womens' cleaning products :grin:
helenm wrote:You've obviously don't know anything about womens' cleaning products :grin:
I thought that soap was used to clean women :lol:
Return to “General DIY forum”
