raising and lowering the top of a tank
thequietcenter
Been thanked: 1 time
Post by thequietcenter » Fri Feb 25, 2011 10:08 pm
Hello, I have built myself a working floatation tank. While the entire process is described in a blog post, all details relevant to my construction issue are here.
In this picture:
you can see a containment tank - a plastic tank that holds water.
In this next picture:
you see two such containment tanks - one facing up and the other facing down, serving as a top. The two containment tanks placed together in this fashion are called a floatation tank.
The two tanks are connected together by the use of a plastic cinch which you can see here:
Now, my question concerns coming up with a way to raise and lower the top. When a person is inside the floatation tank and wishes to get out, he needs to be able to raise the top and have it stay up while he exits. So far, I have been bringing two sticks into the tank with me to raise the top as shown here:
I'm wondering if there is someway to get the top to raise, stay up and lower via some mechanism. The requirements are:
- a person inside the enclosed tank must be able to get the top to raise up (as shown in the picture).
- once the person exits, he should be able to lower the top from the outside
Has thanked: 638 times
Been thanked: 1922 times
Re: raising and lowering the top of a tank
Post by big-all » Fri Feb 25, 2011 11:01 pm
http://www.floatworks.com/
a new concept on me
where are you based :thumbright:
kellys_eye
Has thanked: 290 times
Been thanked: 1559 times
Post by kellys_eye » Fri Feb 25, 2011 11:50 pm
You need to look for gas struts. Gasstruts.co.uk have a wide range in stroke and weight.
mod5
UHM Super Moderator
Been thanked: 61 times
Post by mod5 » Sat Feb 26, 2011 10:57 am
The OP is from the US and probably would not benefit from advice about UK companies.
mod5
kellys_eye
Post by kellys_eye » Sat Feb 26, 2011 6:11 pm
mod5 wrote:The OP is from the US and probably would not benefit from advice about UK companies.
mod5
Nice if he'd indicate that fact though.... :roll:
Still, gas struts are available anywhere.
thequietcenter
Post by thequietcenter » Sat Feb 26, 2011 10:55 pm
kellys_eye wrote:You need to look for gas struts. Gasstruts.co.uk have a wide range in stroke and weight.
ok, well I think corrosion would be an issue because there is epsom salt water in the tank.
And there is some question about how I might secure the strut within the plastic tank, since drilling holes through the plastic is not an option. I'm thinking rubber mats should provide enough traction for the strut.
And finally they would have to extend to about 4 feet high and retract to 32 inches high (twice the height of one the tanks).
but thank you for the advice. I had been looking at pneumatic car hatch lifters up to this point.
thequietcenter
Post by thequietcenter » Sat Feb 26, 2011 10:57 pm
big-all wrote:http://www.floatworks.com/
a new concept on me
Floatworks is run by Tim Strudwick. I've had numerous conversations with him on our floatation tank community sites.
He had an idea of using pulleys attached to the ceiling.
thequietcenter
Post by thequietcenter » Sat Feb 26, 2011 11:11 pm
Staring out spa cover lifters has given me an idea ... maybe I can simply slide the top forward and back instead of lifting it... that is what I was doing before I used the cinch. But the problem is that there are no guides to keep the top tank sliding exactly over the bottom.
Post by big-all » Sat Feb 26, 2011 11:39 pm
my suggestion was going to be a pulley overhead
one end connected to middle front edge off the top
a bag off sand on the other end that hits the floor when the top is open enough
if the pulley is just above the hinge section but clear off the back onto the floor then the weight will help the top stay up and down
if you load up the bag until the lowered lid has a light touch when you lift it above about 25 degrees the weight will open the door until the weight hits the floor
for this to work the pulley would have to be in the region off as high off the floor as the lid is long
thequietcenter
Post by thequietcenter » Sun Feb 27, 2011 5:53 am
big-all wrote:my suggestion was going to be a pulley overhead
I think I will be going with a system similar to sliding doors or sliding windows.
But thank you for your suggestion.
thequietcenter
Post by thequietcenter » Tue Mar 01, 2011 8:33 am
I am very happy that drawer guides (glides) have worked perfectly for me:
Thanks again for all the help!
These users thanked the author thequietcenter for the post:
Post by big-all » Tue Mar 01, 2011 3:37 pm
thank you for taking the time to let us know how you got on we appreciate it thank you :thumbleft:
we will await for an echoey request say" my drawer runners have rusted how do i get out" :huray: :huray: :huray:
thequietcenter
Post by thequietcenter » Tue Mar 01, 2011 7:48 pm
big-all wrote:thank you for taking the time to let us know how you got on we appreciate it thank you :thumbleft:
LOL!
:mrgreen:
Return to “General DIY forum”
