Using a multimeter
- Mr. Grumpy
- Has thanked: 25 times
- Been thanked: 109 times
Using a multimeter
Right from my post below on testing a live wire, I have dug out my old Multimeter (batteries still work - hasn't been used in 7 years at least!!!)
I have no clue how to use it to test a live wire and don't want to try until I run it past you guys.
It says in the instructions that it can measure AC current and Voltage but doesn't say which V what is for AC Voltage, similary with current
Any advice gratefully received!!
- Image 3 (Medium).JPG (35.94 KiB) Viewed 32201 times
- ultimatehandyman
- Site Admin
- Has thanked: 999 times
- Been thanked: 915 times
I have labelled up what each section is for apart from the small area at the top right, I can't make out what that is.
To Measure mains voltage, place the black lead in the com socket and the red lead in the V/ Ohms socket.
Then turn the dial to point to AC volts 700 then you should be able to take a reading.
Extreme caution must be exercised when testing live wires and if possible it is best to test with the electricity switched off.
What exactly are you trying to test?
- image_3_medium_111.jpg (70.21 KiB) Viewed 32190 times
- Mr. Grumpy
Excellent cheers mate.
I was following on from scruffs comments in my previous post that the screwdriver volt meters are not great to use. I have busted it anyway!
I simply want to test if there is electricity flowing through a fused spur that you advised me on a week or so ago. The FCU is feeding undercabinet lightening in the kitchen and so comes from the sockets
Usually I turn off the electricity off at the mains when changing sockets but sometimes I can't see a thing so I leave the lighting circuit on and switch off the circuits from the sockets.
Where do i actually place the leads UHM
Deck,
just saw you post, given my simple requirement, do you think I can use this thing instead of a screwdriver volt meter?
Deck,
- Mr. Grumpy
- Mr. Grumpy
- Mooncat
- Has thanked: 81 times
- Been thanked: 72 times
The section shown here is for testing transistors. You have to identify the type NPN or PNP, and the lead arrangement, plug it in and the meter will indicate the gain.
- thescruff
- Has thanked: 360 times
- Been thanked: 3734 times
- sparkydude
- Has thanked: 2 times
- Been thanked: 149 times
a volt stick has its uses but not in this situation, the multimeter he has is perfectly useable but the only thing i would say is change the leads for a set of fused leads to protect yourself, i had a meter like that when i first started out doing DIY electrics and had no problems with it, But the leads were cheap and nasty and had long exposed tips about 10mm or more which were pretty dangerous when testing live terminals close to each other. Maplins sell a decent range of leads not to expensive either .
Nick
Nick
- Mr. Grumpy
- Has thanked: 775 times
- Been thanked: 3311 times
- sparkydude
To test if the terminals are live then you need to test between live and neutral then live and earth and then neutral and earth just to prove that all cores are dead.
Nick
Nick
- Mr. Grumpy
