Foundations on a 1930's house
Hello,
I have just bought a 1930's house and dug a hole to have a look at the foundations, it only seems to go down around 3 bricks undergound in a kind of foot i.e.
Would this be correct, is it able to be so shallow? it is on clay.
Paul
Paul
- Tryanything
- Been thanked: 4 times
Hi sutt
That is normal probably got a shallow bed of concrete mix underneath
The only trouble with this type of foundation is tree roots and bush's near
to the house that dry out the clay and cause subsidence in very hot
summers (when we get them)
There would be less trouble in the world
if l had not had six daughters
the question has come about because it already had an extension done 1980's without regs i bought it a couple of months ago and have put a new pitched roof instead of the flat one.
got building regs involved to sign it all off and they have asked me to expose the house and the extension foundations so see if they are ok, house goes down about 3 bricks, extension about 1.5. there has been no movement, no cracks etc, roof is alot lighter now.
what can i expect from the inspector when he see them?
Hi I am the dreaded building control inspector! - It's doubtful we would sign off the entire extension as it's too old, the inspector wants to see the foundations due to the new load from the roof, but shouldn't need to see the house foundations unless there are new loads applied to it from the roof (doubtful). Highly unlikely they'd ask you for underpinning if it's on good clay material.
- ultimatehandyman
- Site Admin
- Has thanked: 999 times
- Been thanked: 915 times
Hi Andy,andy.pottle wrote:Hi I am the dreaded building control inspector! - It's doubtful we would sign off the entire extension as it's too old, the inspector wants to see the foundations due to the new load from the roof, but shouldn't need to see the house foundations unless there are new loads applied to it from the roof (doubtful). Highly unlikely they'd ask you for underpinning if it's on good clay material.
Welcome to UHM
