Can't get kitchen mixer tap apart!!
plumbing, drainage and waste water questions here please
bumface11
Post by bumface11 »
Did you manage to get the handle off? I've got the exact same problem. Grub screw came out, but handle is still firmly attached.
moderator2
UHM Super Moderator
Has thanked: 154 times
Been thanked: 558 times
Post by moderator2 »
:welcomeuhm: Best not to dig up a four year old post . I have split your post from the old thread.
As I understand it, a Franke monobloc tap with a drip and the handle won't easily part from the main body?
bumface11
Post by bumface11 »
Problem solved. Unscrewed the valve cover as far as I could to prise the handle a few mm, then levered it with a screwdriver. Used quite a bit of WD40 as well. It's a Franke Eiger tap.
Return to “Plumbing Forum”
