Hi All,
After a bit of advice.
I am painting 4 french doors, frame and architrave in my downstairs kitchen/diner.
The doors were fitted pre primed, the architrave is bare pine and the frame is original.
The frame has a gloss finish on it and this has a yellow tint to it.
Based on the research I have done, I have the following approach in mind to get them looking spot on:
BIN Zinsser on architrave and frame x 1 coat
Johnstone Aqua undercoat x 1 over the lot
Johnstone Aqua Satin x 2 over the lot
Would welcome any feedback on this approach.. I’m after a nice white, long lasting finish without having to use oil based paints.
My house is quite narrow and long so natural light doesn’t really hit the centre of the house. I used QD satinwood Once, all over my skirting 2 year ago and this is starting to yellow.
Thanks in advance
Water Based Satin
- Has thanked: 773 times
- Been thanked: 3303 times
Water Based Satin
It is my choice of paint combination for a job like that. See my tips link in blue below which may help in some regards.
- Harper89 (Sat Jun 27, 2020 9:15 pm)
- Has thanked: 2 times
Water Based Satin
Thanks DWD
I will get going next week, appreciate the response, your article is very good.
Out of curiosity, each french door has 4 panes of glass, what steps would you take to ensure you don’t get paint on the glass when cutting in?
Water Based Satin
I am crap at cutting in, I mask up or scrape overpaint when it is set. One point to note is that Aqua takes a while to harden if you use the paint and scrape method. I am not a pro painter.
- Harper89 (Sun Jun 28, 2020 12:44 pm)
