Outside Lamp with switched PIR.
Hello All.
Please can anyone tell me how to operate my PIR lantern which has a switch set up, rather than the usual 2 dials?
The image shows the settings as delivered.
No instructions to tell me what the symbols officially represent, though it is probably common sense.
I don't know which one is for sensitivity (as in movement trigger).
Thank you.
Thank you.
- Switch.jpg (173.12 KiB) Viewed 1733 times
- Someone-Else
- Has thanked: 42 times
- Been thanked: 2482 times
You asked the same question Last year
and you still get the same answer
If you still can't find any information on the light, I suggest you buy a new different one, or better still, do as I suggested last year, buy a light AND a PIRsomeone-else wrote: ↑Sun Dec 22, 2019 7:44 pmWhat does google show in regard to the instructions? (I would have looked but you do not give any information about the actual light)
- Argyll
- Has thanked: 1168 times
- Been thanked: 571 times
Fantastic reply SE.
Valuable information. If in doubt, just buy another one.
You must be great with your recycling.
Unlike you, I won't give up.
I'll get back to you, when I suceed.
- Someone-Else
I hope you do. But bet you won't.
There is no "standard" as to what the switches do, as I said 6 months ago, why not try the switches and find out what they do. Now you know why it only cost £12.
- etaf
- Has thanked: 37 times
- Been thanked: 137 times
my best guess would be
DIP switch 3 to 6 - time the light is on
the 8,1.3,5 have the seconds and minutes symbol
8'' seconds , 1' minute, 3' minutes , 5' minutes - BUT how they combine when more than 1 on , not sure
The sun and moon would be the light sensitivity setting , switch 1
The movement Detection area/sensitivity is the symbol used for switch 2
my best guess
make and model of the PIR may help , as there is a lot of user manuals online
you can some of the symbols used on this device - see image for DIP switches
https://www.amazon.co.uk/LED-Logic-Ceil ... B007MOBXDU
my best guess
Simple DIYer
Wayne
Wayne
Thank you eTaf.
Your advice is an immense help, especially with the amazon link. A brilliant find!
That is how I read the switch display, so I suppose a little bit of trial an error.
I am also guessing that switch 2 is the trigger sensitivity for the distance.
